Old 11-17-2007, 03:24 PM   #1 (permalink)
k09xtreme's Avatar
Member Number: 55295
Default Wire modernperformance halo/LED lights
just got the headlights in and they work fine. I just need some picture to tell what exactly to do.
k09xtreme is offline   Reply With Quote
Old 11-17-2007, 06:50 PM   #2 (permalink)
Member Number: 31038
Trader Rating: (34)
raul-01 is online now   Reply With Quote
Old 11-18-2007, 09:17 AM   #3 (permalink)
k09xtreme's Avatar
the right side LED wont work and now my gauge cluster lights are not working
Old 11-19-2007, 04:15 PM   #4 (permalink)
Member Number: 23973
did you solder or just use crimps and such? My left side LED'
s arent working. And as far as the dash, check you fuses
2005 Stone White
MODS!
Redstar Returnline
Walbro 255
Perrin Fuel Rail
AGP WG 21 fall to 15
Psi Fi Motor Mounts
AGP Hard Pipes Greddy Type RS
QW FMIC
AEM WideBand
30/30 Boost Gauge
PWerks F/R Strut Tower Bars
Waiting to go in.. DW 750s DTEC FCBC
9Formula8 is offline   Reply With Quote
Old 11-19-2007, 04:41 PM   #5 (permalink)
BoostJunkies's Avatar
Member Number: 50062
Trader Rating: (26)
you blown a fuse -_-
BoostJunkies is offline   Reply With Quote
Old 11-20-2007, 05:28 AM   #6 (permalink)
k09xtreme's Avatar
yeah i got everything working except the passenger LED's so modernperformance is sending me a new pair b/c the LED's were bad.
Old 11-21-2007, 05:34 PM   #7 (permalink)
bsbob's Avatar
Member Number: 5248
Trader Rating: (26)
I had no ISSUES with the wiring, it was the fitment that SUCKED! got it all together to find the PIN that locates the light in the fender was TOO BIG! after taking my small grinder to it, the housing set in fine. OMFG, the lenz to bumper gap was bigger than JABBA-THE-HUT! i use my car basically for show, so this was UNACCEPTABLE! took a minute to realize it was the CHEEZEY GASKET SURROUND which was the problem! having my stock lights, i pulled the gasket swap and now everything FITS AS IT SHOULD. if you guys and girls install these lights, do yourself a favor ahead of time, FILE or GRIND the pin and install your factory headlight gasket AHEAD of time. if you do, the install is HONESTLY about an HOUR with the wiring. HOPE THIS HELPS! BSBOB P.S the lights are GREAT, even with my EYELIDS!
bsbob is offline   Reply With Quote
Old 11-21-2007, 11:48 PM   #8 (permalink)
Member Number: 58962
hey bsbob do u have pics of the headlights on your car i wanna see how they look ... the tiny little picture of an avatar makes it hard to see ur car
eBlueSkittle is offline   Reply With Quote
Old 11-22-2007, 02:40 AM   #9 (permalink)
How did you find out your LED's were bad? Cause my driver side LED's dont light.
Old 11-22-2007, 07:07 AM   #10 (permalink)
bsbob's Avatar
Member Number: 5248
Trader Rating: (26)
thats my old avatar anyway, just did the projectors last night. will take some photos later today and post em up! BSBOB
Old 11-22-2007, 07:54 AM   #11 (permalink)
k09xtreme's Avatar
Yeah BSBOB i had the same problem with the PIN and the gasket but luckly i still had the stock lights and just put the stock gasket on. and to check if the connection isn't good i just went to advanced auto parts picked up a test light and just checked all the wires and figured out the housing to my passenger LED's was bad.
Old 11-23-2007, 08:48 AM   #12 (permalink)
Thanks, I'll have to check it. Can anyone post up how they wired theirs? I wired mine like we did my friends on his cobalt, But I guess that it was different, My halos only come on with the headlights. For his car they come on with his running lights also. I didn't get wiring instructions with mine.
Old 11-23-2007, 06:43 PM   #13 (permalink)
bsbob's Avatar
Member Number: 5248
Trader Rating: (26)
HEY GUYS, heres the pics of my projector install. did the photos late this afternoon, so are a little dark, but you get the idea. as far as the wiring goes,both black wires go to the black on the socket plug. white wire on the halos goes to the black/ yellow and the white on the LED goes to green/ orange or brown/ red depending on left or right. hope this helps. BSBOB
Old 11-24-2007, 09:47 AM   #14 (permalink)
k09xtreme's Avatar
well if you got the headlights from modernperformance there should be some type of instructions, if not give them a call and i'm sure they would be happy to send you some. Basically all you need to know is what bsbob said with all the wires. both black wires go to the black on the socket plug. white wire on the halos goes to the black/ yellow and the white on the LED goes to green/ orange or brown/ red depending on left or right.
Old 11-24-2007, 11:15 AM   #15 (permalink)
bsbob's Avatar
Member Number: 5248
Trader Rating: (26)
got a DAYTIME shot! BSBOB
» Sponsor Links
»Garage Storage and Cabinets
