Guys, after reading many threads about it, and seeing how horrid my beam pattern was with my aftermarket hid's...I decided to try and do something about it. After playing with it for 2 nights now (not done yet) here is what I've come up with...
This is my beam from one headlight (not in car, I was holding it. And sorry for the grainy pic). I acheived this using a custom made shield for my HID bulb. I am not done, I still have more playing around to do, but so far, the results look pretty promising...
Also, don't think that this is a perfect mod, initial tests show that light output is diminshed a bit, although it is hard to gauge how much because I have only done one light so far. I think that modifying my sheild a bit more may let more light through. Pros so far include MUCH reduced glare, filtering out the yellow/orange light that is produced out of the bottom of the hid and a much better cutoff. More pics to come when I do more!.
OK HERE IT IS!!!....
after some tests and such..this is what I came up with.
Here you can see my bi-xenon HID bulb, as you can see i drilled some reliefs around the base...I did this to give the JB weld something to hold onto (for some reason it kept falling off this one bulb).
Here is a pic of my bulb with my shield next to it. For the shield I used some aluminum flashing. Its very thin and light, easily cut with tin snips, and all for all it seems to have been a good choice. I wrapped it around a marker which happened to be just the right radius to get around my bulb.
Then I simply mixed up some jb weld and glued my shield to the base of the bulb. Notice that the shield should cover the bottom half of the bulb, NOT, the top half.
Finally, pics of it installed in the headlight housing. I found that tipping the bulb down in the housing made the beam MUCH sharper at the cutoff. To do this I placed a piece of wire as a space between the base of the bulb and the housing on the bottom to space it out. then when I put on the clip to hold the bulb in, I only caught it on the top two screws.
That is it for now. I have one installed in my headlight, and the other is waiting for the jb weld to dry (the shield fell off the bulb when I was trying to install it...hence me drilling those reliefs).... I hope to install them back into the car semi-soon. I just made a new dual-relay harness and bought a new battery. I'm gonna install my tranny mount before I put it all back together though. I'll post up pics of the beam pattern when I do!!!
Installed in car....
needless to say I am very disappointed at my results. As you can see there is a HUGE difference between the first Pic I showed of the beam pattern vs. this one. This is because of my shield modifications. The beam pattern above is using the shield that I showed you pictures of. The beam pattern at the top of the thread is using one that had a shield that covered about 75% of the bulb, as opposed to this one which covers 50%. I am not sure yet if I'm going to rip the headlights out again and re-make the shields to cover the 75% or leave them be.... Just a little angry right now.
