Old 09-09-2008, 08:54 PM   #1 (permalink)
Pomz23's Avatar
Member Number: 64878
Trader Rating: (19)
Question where can i "t" in to get power only when the ignition is on???
Im setting up some lighting, but i want it have a 3 way switch included. the lights will light up the grill and nostrils but i want the switch to work:
Position 1: lights are on
Pos:2 Off
Pos: Lights only on if ignition is on.
i know how to hook it up so it is always on, but where can i tap into to get power when the ign is on?
Pomz23 is offline   Reply With Quote
Old 09-11-2008, 07:36 AM   #2 (permalink)
kagekun's Avatar
Member Number: 57941
Place I use for everything cause its simple, use the IGN wire on your cdplayer, assuming you have a aftermarket head unit that is
Meth Addict & CM is my dealer
http://www.cardomain.com/ride/3219131
kagekun is online now   Reply With Quote
Old 09-11-2008, 08:25 AM   #3 (permalink)
Dumetre's Avatar
Member Number: 23004
I just run the wires to the fuse panel by the drivers door and use a test light to find a good source when I need another one.
Dumetre is offline   Reply With Quote
Old 09-11-2008, 12:09 PM   #4 (permalink)
Pomz23's Avatar
Trader Rating: (19)
thanx but can you tell me which one you used??
Old 09-11-2008, 12:11 PM   #5 (permalink)
Pomz23's Avatar
Trader Rating: (19)
i know the fuse for the cig lighter is under the hood and that is only powered then the ign is on, but where can i find the wire that uses that fuse
Old 09-11-2008, 12:49 PM   #6 (permalink)
Dumetre's Avatar
I used a bunch of different ones but my car isnt here to look at. If you have a test light you can find one in about 5 seconds.
Old 09-11-2008, 01:11 PM   #7 (permalink)
Pomz23's Avatar
Trader Rating: (19)
how do i do that with a test light, then once i know which fuse it is though, how to i connect into it? like how do i know what wire is what fuse>
Page generated in 0.21727 seconds with 13 queries
