Old 02-23-2004, 05:45 PM   #1 (permalink)
SRTTurbo's Avatar
Member Number: 5464
Default Whats the safe wattage for an SRT.
What is the Safe wattage for the SRT. I wanted to get the 100/80 watt xenon bulbs http://store.yahoo.com/mobile-emotio...enlowbeam.html.
Would the SRT's wireing harness support this amount or not. I want a bulb that has a bluish tint. but not silverstars. I searched and searched on here and didnt find what i was looking for exactly. Thanks in advance.
Mike
Best time Street tires stock turbo setup 13.501@103.31
AGP 3147 Stage 3 T3/T04 turbo kit, MaxxFab DP, PTP CV, DC's strut bar,180 degree stat, magnacore wires, ngk V-power plugs, AGP 3" CAI, IP2 filter, AEM UEGO AFR Wideband, Mopar STS, Mopar Stg 1 Springs, Booger Bushings, ebay CC, Deyeme MM's, Turbo XS RFL, Mopar Borla Exaust, IP2 CF Hood, CF kanards, CF Foglight bezles.
SRTTurbo is offline   Reply With Quote
Old 02-23-2004, 06:04 PM   #2 (permalink)
srtowner's Avatar
Member Number: 4573
Trader Rating: (78)
Iwould like to know the same thing ,wish someone would reply.
FOR ALL YOUR PERFORMANCE NEEDS
srtowner is offline   Reply With Quote
Old 02-23-2004, 09:40 PM   #3 (permalink)
BlaSRT4's Avatar
Member Number: 974
ive run bulbs with that wattage for 6 months now with no problems.....going to get HIDS soon now tho....gotta move up in the world
03 Blk SRT4
03 RRP RSX-S
BlaSRT4 is offline   Reply With Quote
Old 02-24-2004, 02:33 PM   #4 (permalink)
noblebc's Avatar
Member Number: 5011
Higher wattage gives a higher risk of damaging the lighting system. I am not saying this is what is going to happen just it has a much greater probability. The higher wattages increases the heat in the wiring harness which could damage it. There will also be increased heat at the base of the lamp, potentially damamging the housing and also more heat in the fixture damaging the reflector or plastic front.
The higher wattage is also not street legal. Federal rules say you can not have higher wattage for use on the street because the system is not designed for it, hence you are increasing light in oncoming traffics field of vision. It may benefit you as the driver but not everyone else around you that might feel blinded by the increased light.
I hope this helps you understand the issue with this.
noblebc is offline   Reply With Quote
Old 02-25-2004, 06:55 AM   #5 (permalink)
Member Number: 4517
Stick with stock wattage. I hate having someone with no respect for other drivers shining 100W bulbs in my eyes.
Narcisse91 is offline   Reply With Quote
Old 02-25-2004, 07:21 AM   #6 (permalink)
Slvrstreak's Avatar
Member Number: 626
i've had the 100/80 watt bulbs in my car since i bought the car a year ago, and no problems whatsoever. i had those same kinda bulbs in my 98 neon before, and they were in my car for yrs w/ no problems.
03' Dodge SRT-4
05' Subaru STI
"SEYAH"
Slvrstreak is offline   Reply With Quote
Old 02-25-2004, 05:47 PM   #7 (permalink)
SRToc Member
shelby guru's Avatar
Member Number: 7858
I have the 80/100 watt APC's and no problems. It has only been 6 weeks for me though. I picked up some 893's (37.5 watts) that were also "blue-ish" the other day for the fogs. However, I can't get my fat hand up there to change the pass. side without removing the WW bottle. I would love to know why the owners manual states the fogs are 9145's when they are really 890's.
Also (for the record)...I ran 80/100's in my Dakota R/T and 885 Fogs (50 watts) for 4 years with no problems. However, in my Omni GLHS I ran 80/100 Hellas and remember the moment (like it was yesterday) when the Headlight Switch MELTED in the "ON" position! Disconnecting the battery everytime I parked the car (for a day or two) was a pain!
shelby guru is offline   Reply With Quote
Old 02-26-2004, 12:08 AM   #8 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
The weak point in the Neons headlamp circuit is the multifunction switch on the steering column. I plan on upgrading the harness with some 12ga leads and 40A relays. Upgrading the circuit alone should kick out a few more lumens.
James
READ AND LEARN:
Old 02-26-2004, 08:28 AM   #9 (permalink)
noblebc's Avatar
Member Number: 5011
I hate to keep saying this but going to a higher wattage is bad for oncoming traffic. Wiring seems to hold up so that doesn't seem to be the point I can battle on. Using the higher wattage lights are not legal and are dangerous to others. Of course I am going to say use SYLVANIA but really I would rather have people choose a Philips or GE street legal bulb over the 100/ 80 watt blinders. There is just too much light hitting eye level oncoming traffic making for unsafe driving.
Page generated in 0.23437 seconds with 13 queries
