Old 06-21-2009, 05:08 PM   #1 (permalink)
Pomz23's Avatar
Member Number: 64878
Trader Rating: (19)
Default Is there an easy way to brighten the halos on projector housing headlights??
Just bought the projector housing headlights. Is there any way I can increase the brightness on the halos without replacing the bulbs. Something like adding a capacitor to the wire? or no?
Metal Werkz - For Sale: New Custom Aluminum Door Sills and Radiator Shrouds!!!!!! Click here for my site.
Pomz23 is offline   Reply With Quote
Old 06-21-2009, 05:37 PM   #2 (permalink)
wiggyx's Avatar
Member Number: 58107
Trader Rating: (53)
Nope. They suck (as far as output is concerned). This would really be you best option. The cheapest retros you can get.
ND4SPD DESIGNS Projector Retrofiting
Old 06-21-2009, 08:58 PM   #3 (permalink)
tbillz715's Avatar
Member Number: 65315
I think he means brighten the halos.. Maybe wiggy means do what ND4SPD did with the other LED's. I'm about to order these headlights too..
05' OB SRT-4
-AGP Motor Mounts
-K&N Short Ram intake
-Halo headlights & fog lights
-More to come soon.
tbillz715 is offline   Reply With Quote
Old 06-21-2009, 09:12 PM   #4 (permalink)
wiggyx's Avatar
Trader Rating: (53)
Oh, my bad. LOL, I've never heard that question before. I just assumed you meant the projectors (which people ask about all the time). I'm not sure. Unfortunately, replacing the LED's is prolly the only way to get them brighter.
Old 06-21-2009, 09:35 PM   #5 (permalink)
Pomz23's Avatar
Trader Rating: (19)
Quote: Originally Posted by wiggyx View Post
Oh, my bad. OL, I've never heard that question before. I just assumed you meant the projectors (which people ask about all the time). I'm not sure. Unfortunately, replacing the LED's is prolly the only way to get them brighter.
Yeah thats what I ment. My buddy has the CCF(I think that it??) and they are way brighter. you cant even see them when the lights are on.
Old 06-21-2009, 09:40 PM   #6 (permalink)
wiggyx's Avatar
Trader Rating: (53)
Cold Cathode Fluorescent? Yeah, but that would require that you take apart the headlights to install for sure. They look great though.
Old 06-22-2009, 12:58 AM   #7 (permalink)
tbillz715's Avatar
Ok this is a little off topic but I don't want to start another thread about the MPx lights.. Has anyone had any problems with condensation? I might get some silicone or something and double seal them before putting them in.
Old 06-22-2009, 02:39 AM   #8 (permalink)
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (50)
There's a little box double side stickied on the back of the housing with wires coming out. You can cut the wires, remove the box & re-connect the wires. This will run the LED's at full power which is considerably brighter. Unfortunately they will die a certain death as most LED's don't like the heat produced. It also don't provide much wiggle room for power surges which can kill them also.
CCFL's can be installed or the LED Rings like I've done. Both are significantly more money then just some bulbs & require the headlights to be opened up. If there was a better or easier way I would offer it.
John Ruckman
Stage 3 with all the goodies
See My Ride
ND4SPD DESIGNS
Old 06-22-2009, 08:13 AM   #9 (permalink)
Pomz23's Avatar
Trader Rating: (19)
can I remove the box, like you said, and just place a resistor there instead? that way, its an increase in power, just not high enough to blow them out?
Old 06-22-2009, 08:51 AM   #10 (permalink)
wiggyx's Avatar
Trader Rating: (53)
That's probably all the box is, a resistor.
Old 06-22-2009, 08:52 AM   #11 (permalink)
Pomz23's Avatar
Trader Rating: (19)
So i Could just put a lower value resistor on it??
Old 06-22-2009, 09:04 AM   #12 (permalink)
wiggyx's Avatar
Trader Rating: (53)
Most likely. Either way, whether you pull the resistor completely or replace with a smaller one, you're gonna kill 'em off a lot quicker. Then to replace them I think you need to open the lamps up anyways Personally, I would maybe think about opening them up and adding a higher wattage set of LEDs. Those lamps bake apart really easily and it would cost a lot less than going the CCF route. Maybe John has a better (easier)solution?
Old 06-22-2009, 10:37 AM   #13 (permalink)
Member Number: 73326
You might be able to fit two superflux led's in place of the original two.
mcole254 is offline   Reply With Quote
Old 06-23-2009, 03:57 AM   #14 (permalink)
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (50)
CCFL's fit nicely in place of the stock crappy halo's. That's the next best & easiest option IMHO. They are bright enough to see during the day & last a long time. They have a wide viewing angle so head on the upgraded LED's I use are brighter but from a 45 deg angle they are about the same.
The 3 Side Led's are Superflux style Led's in 194 sockets (easy & cheap to replace). The stock LED's for the Halo's are the issue as they use this wierd & dual 3mm led's soldered to a small board. If you want to upgrade them you're going to have to make something custom.
Old 08-18-2009, 02:42 PM   #15 (permalink)
Member Number: 68050
i removed the box and they came on for a split second like the blew. So where do i get these CCFLs?
botlfed98 is offline   Reply With Quote
Page generated in 0.22449 seconds with 13 queries
