Old 03-02-2004, 11:11 PM   #1 (permalink)
go_BLUE_2's Avatar
Member Number: 6766
Trader Rating: (21)
Default SRT-4 lighting Specifications
Does anyone know where I can find out exactly what the current draw is on the turn signal/parking lights, reverse lights, side markers, headlights, etc. without physically removing the bulbs and looking at them?
Also, is there a source that shows what the maximum current draw can be for any of these bulbs?
Any info would be very useful
Thanks
Tony
06/17/05 12.659 @ 110.58 - 8.5/24.5-15 Slicks
05/22/05 307.54 HP / 381.20 TQ - Stock Turbo
go_BLUE_2 is offline   Reply With Quote
Old 03-02-2004, 11:15 PM   #2 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Here's the list. I'm sure you can likely find the specs around on
http://www.sylvania.com/bin/carApp/c...=Neon&x=44&y=3
James
READ AND LEARN:
Old 03-02-2004, 11:18 PM   #3 (permalink)
go_BLUE_2's Avatar
Member Number: 6766
Trader Rating: (21)
I have been to there site, but I am not finding the specs I desire. I am looking at getting some of the LED bulbs from autolumination, but I do not want to exceed the stock current draw by much... Sylvania's site, if anything will show me what kind of draw their bulbs have, but I did not even see that info on their site other than for headlights..
Old 03-02-2004, 11:23 PM   #4 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Oh, well LEDs won't draw nearly 1/10th the current that the stock incandescent bulbs do. If you went LED, you're safe as far as current draw is concerned.
Besides, thats what fuses are for
I know the 3457/3157s are 27W. I don't know if that is with bith filaments (likely) or not.
Old 03-03-2004, 07:16 AM   #5 (permalink)
go_BLUE_2's Avatar
Member Number: 6766
Trader Rating: (21)
I saw that they have a 3157 bulb that has 20 LEDs in it. Are you saying that each LED bulb draws 1/10th the current (20 x 1/10 = 2 times the current draw of the regular bulb) or the group of them together draws 1/10th the current?
Thanks!
Old 03-03-2004, 08:14 AM   #6 (permalink)
noblebc's Avatar
Member Number: 5011
The major issue with LEDS is not current draw but the amount of heat they produce. I know that is one thing we have been dealign with in looking at LEDs over the past few years.
noblebc is offline   Reply With Quote
Old 03-11-2004, 01:43 AM   #7 (permalink)
Member Number: 8898
noblebc is right, I put in some LEDs and actually started getting weird electrical warning signals like a bulb was out because they didn't draw enough current so the computer thought it the bulb was dead!
ChillyFry is offline   Reply With Quote
Old 03-11-2004, 05:22 AM   #8 (permalink)
go_BLUE_2's Avatar
Member Number: 6766
Trader Rating: (21)
I believe that is why they make the LED load equalizers such as the ones seen here:
http://autolumination.com/equalizers.htm
I think that they are pretty much just a resistor that you wire up with the LED bulb so that there is a larger current draw than with just the bulb alone.
Page generated in 0.17299 seconds with 13 queries
