Dont look for bi xexon. Single beam's all u need. you cant have high beams in the projector, the high beam is the bulb next to the projector. + its pointless to have high beams with hids, they dont do shit. and thats coming from someone that had them.
ooo ok lol i had them in my stock headlights and my kit got all messed up so i figured i would upgrade
I would not do hids seeing the halos from modern. I had the hid bulbs burned so badly thats why I went with ebay halos and I upgraded the the h1 bulbs bright enough without blinding anyone. I was like running 3000k hids in the halos that burned . I also had a relay harness.
Instead of spending money on that why not get a retrofit from one of the guys on here? Its a little more money but the end result will be 100x better than that junk you're about to buy. Not only does a retrofit look better, but it's going to perform a lot better to.
THat wont help your halo headlights when the hids burn them up or melt them up . You wont have any headlights for the hids replacement . If I would of started over again I would get a retrofit like some on here instead of these cheap version of projectors.
dont wanna spend over 500 $ on a set of headlights is not a priority to me got other things i would rather spend that on my headlights got all messed up thats why im getting the new ones i figured instead of getting a regular headlight spend 50 more bucks and get something that will change the look of my car...i was going to do retros but again decided against cuz of the money for it.
yess get the ebay projectors and put the 35 dallor raptor kit from ddm in the projector housing and put the 55 watter in the high beam hole it will be an amazing amount of light
HIDS for the winn
ddm tuneing has amazing kits and a helll of alot better deal then some vendors
the 35 watt hids burn cooler and put off less heat then a halogen bulb i have the exact set up i told him to get and its amazing i have had hids in 5 different cars with standard housings and never had a problem
