Simple fix for those wanting their fogs on with highbeams
But to update this thread. Me and another member were discussing and we think this might be an overload possibly for halogen users because of both filaments going at the same time. That could be a possible overload on our weak stock system so I do not advise this for halogen folks! This is however safe for those that have bi-xenon HID in their car such as a bi-xenon retro or a 9007 hi/low HID kit. In that case it would be perfectly safe.
For HID bi-xenon people. Inorder to have your solenoid work properly and not shut down your lowbeam, you will need to place this diode from your highbeam wire to your lowbeam wire. In addition, this will also give you fog lights on with both low and high beam unlike the stock set-up where they used to cut off during highbeam operation.
Here's the steps involved.....
Step 1: Remove headlights
Step 2: Open up the loom that hold the three wires for the headlight plug.
Step 3: Place 6 amp diode in between the low beam positive (+) wire (purple) and the high beam positive (+) wire. NOTE- diode stripe goes on the low beam (purple wire).
Step 4: ENJOY! Your done!
Thought some of you might like to know this tidbit of info. I found it out when I was wiring up my bi-xenon solenoid hehe.
I found quite possibly the easiest mod out there for those looking to want to have their fog lights NOT shut off when the highbeams are on.
pictures??
500 AWHP, 433.XX TQ., 95.XX dyno room temps Best Trap: 12.2 @ 124 MPH
Best E/T 11.8 @ 120 MPH
Why you need pics? Its exactly how I said to do it lol. Remove the headlight and open the loom exposing the wires going to the headlight plug. Install diode and done. Easy as pie. I'm not going to remove my headlights again for a LONNNNNG time due to this retro I just got done with.
I am mecanically inclined but not electricaly inclined unless I see diagrams/pics.... heck I dont even know what I diode is...
Wish granted
However after thinking this thru, this will also make your lowbeams stay on too. So basically when the highbeams are on, your highbeam filament and lowbeam filament in the headlight bulb PLUS fogs will be on.
i did the ghetto $.75 fog light mod on my SXT:
And the fuse box:
That green wire now has a simple lighted toggle switch on it now.
Works just like that other mod, but is about a 5 minute install, and can be removed later if you so desire. I've been running that on my SXT for about 4 months now with out a single problem.
Just cut the green wire in half, and install your choice of switch assembly.
Car needs to be on btw, but switch to high beams and the fogs stay on.
Canon EOS 30D|Canon EF 28-135mm f/3.5-5.6 IS
Canon 18-55mm (kit lens), Canon 50mm f/1.8 II
SanDisk 8GB ExtremeIII | Canon 580EX Flash
Nice, but the way I'm showing eliminates the need for a switch.....I don't care for switches and all in my car if I can help it. Cleaner to me w/o it. If it works for you, thats cool.
with the diode setup will the fog lights work with out the lights on?
Nope.
I have also edit the first post to reflect the change.
