Old 05-07-2009, 02:19 PM   #1 (permalink)
Sil'vr-Boi6's Avatar
Member Number: 67935
Default Sil'vr-Boi6's:TSX retrofit
Well-- so I finally decided to give this retro a try. After reading through Boostlee,ND4SPD,Wiggy,NJKiko,Novak's, aww sweet,Lilsparks,Ude Lose, etc.... I decided to begin my retro.
My goal was to keep the the headlight looking OEM spec as possible(well generally speaking, my entire car!). So I approached the headlights in the same manner.
I choose: the TSX projector for its compact size & for its benchmark quality in light output in the industry and simple no nonsense goal).
Type 1 shroudsfor their simple design, chrome/metallic finish that I want blending to the reflectors.)
Plexi/Lexan Glass (for strength/rigidity; since I have BC inverted Coilovers I wanted to mount to something very rigid since* my Coilovers are on firm settings all the time.)
Below are the TSX projectors:Note their compact size.(Dimensions can be retrieved from aww sweet sticky).
<a href="http://s596.photobucket.com/albums/tt50/Boi6/?action=view&current=DSCF0114-1.jpg" target="_blank"><img src="http://i596.photobucket.com/albums/tt50/Boi6/DSCF0114-1.jpg" border="0" alt="Photobucket"></a>
Type one shrouds as you can see below; they will not go over the shroud without trimming. * Not the best pic.
<a href="http://s596.photobucket.com/albums/tt50/Boi6/?action=view&current=DSCF0172.jpg" target="_blank"><img src="http://i596.photobucket.com/albums/tt50/Boi6/DSCF0172.jpg" border="0" alt="type1_oncomputer"></a>
Here side profile of the projector mounted the shroud and housing:
<a href="http://s596.photobucket.com/albums/tt50/Boi6/?action=view&current=DSCF0209.jpg" target="_blank"><img src="http://i596.photobucket.com/albums/tt50/Boi6/DSCF0209.jpg" border="0" alt="Photobucket"></a>
-I'll post picture later on how I mounted the plexi-glass to projectors(sandwich style), and where I shaved the projectors to attain adjustability.
-And clearance trouble that I experienced and solved. NOTE: projectors above are not even close the lense at all> hint rear clearance problems.
Sil'vr-Boi6 is offline   Reply With Quote
Old 05-07-2009, 02:21 PM   #2 (permalink)
Senior Moderator
kritical's Avatar
Member Number: 49262
Trader Rating: (138)
pics dont work?
kritical is offline   Reply With Quote
Old 05-07-2009, 02:28 PM   #3 (permalink)
Default Do you see.
Quote: Originally Posted by kritical View Post
pics dont work?
Sorry...still learning : do you see a picture of TSX projectors
Old 05-07-2009, 02:29 PM   #4 (permalink)
Default Do you see
pics dont work?
Old 05-07-2009, 02:29 PM   #5 (permalink)
SRTforums Junior Admin
JohnnyB's Avatar
Member Number: 58545
Trader Rating: (34)
pics don't work at all
JohnnyB is offline   Reply With Quote
Old 05-07-2009, 02:29 PM   #6 (permalink)
Senior Moderator
kritical's Avatar
nope, no pics..
Old 05-07-2009, 02:30 PM   #7 (permalink)
JohnnyB's Avatar
Trader Rating: (34)
this pic works
Old 05-07-2009, 02:37 PM   #8 (permalink)
Default Sorry about the Re-post
Sorry for the Re-post
Type one Shrouds ;see below; they will not go over the shroud without trimming. * Not the best pic.
Old 05-07-2009, 05:31 PM   #9 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (30)
Those are going to look great!
S256 non extended tip F/IC tuned by Aaronneon
11.88@116 1.74 60'
Old 05-07-2009, 05:33 PM   #10 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
excellent work my friend. thats how my current ones are; all chrome.
View Modifications
Old 05-07-2009, 10:46 PM   #11 (permalink)
Ude Lose's Avatar
Member Number: 4562
Trader Rating: (31)
Lookin good, get some detailed pics up.
Ude Lose is offline   Reply With Quote
Old 05-08-2009, 02:13 AM   #12 (permalink)
Novak94's Avatar
Member Number: 45523
Looking good so far
Novak94 is online now   Reply With Quote
Old 05-08-2009, 08:05 AM   #13 (permalink)
Default Thanks
Thank you all for the positive comments. Negative comments are welcomed too. I hope to learn more from my mistakes and would appreciate if you can comment on where you see future problems. I'll will post more pics at 7PM.
Old 05-08-2009, 10:11 AM   #14 (permalink)
Neon Nick's Avatar
Member Number: 18097
I like the stock chrome look, if I ever did retro's that's how I would do it. Keep them as OEM looking as possible. I don't like all the blacked out ones..
Boosted Fools Racing - Forums
'04 Dodge Neon SRT-4 - 12.83 @ 103mph
Mods: 3" Needswings y-pipe, Stage 1 PCM,
AGP MMs, AGP WGA, M&H 24.5x8.5x15 slicks
'95 Dodge Neon SOHC Turbo - 14.45 @ 97mph
Neon Nick is offline   Reply With Quote
Old 05-08-2009, 10:53 AM   #15 (permalink)
Remax Realtor's Avatar
Member Number: 3827
Trader Rating: (53)
One issue you might have is the light hitting the turn signal shroud. Its not going to really hurt your light output, but it could cause some light to scatter. Mine hits it a little bit, but it reflects on the sides of the car on the road, so it makes the beams look alot wider. I would fire it up to how it looks and make sure you're ok with it.
2003 srt-4 *totaled*
2001 neon r/t with srt swap *sold*
2009 dodge caliber srt-4
Page generated in 0.19768 seconds with 13 queries
