Old 11-29-2005, 02:30 PM   #1 (permalink)
Orlandoech's Avatar
Member Number: 36006
Trader Rating: (105)
Default Replacing stock bulbs with Hypers? HOW???
Ok i bought some Luminics Blue Hyper lights and I can get the passenger light in easy and fine.
Whats the easiest way to install the drivers side bulb, since the stock air box is in the way?
Should I remove the air box or unbolt the whole light and take it out that way?
thanks
Orlandoech is offline   Reply With Quote
Old 11-29-2005, 02:52 PM   #2 (permalink)
Support@4Headlights's Avatar
Member Number: 28972
Trader Rating: (21)
Unbolt the headlight and take the screws out of the top of the bumper cover (3) the headlight comes right out.
Support@4Headlights is offline   Reply With Quote
Old 11-29-2005, 02:54 PM   #3 (permalink)
Orlandoech's Avatar
thanks
i figured that was the easiest way
also will this cause leaks or anything
Old 12-01-2005, 06:37 AM   #4 (permalink)
Member Number: 12666
The bumper cover is very flexible.
Just take out all the screws on top, holding the bumper cover on.
Un-bolt the headlight and remove the entire thing.
Replace bulbs.
Reinstall headlight.
Reinstall bumper cover screws.
There will be no leaks since you aren't actually opening the headlight. Also, take care in re-installing headlight as to make sure the rubber surround is neatly covering the fender.
Done.
"There's nothing better than TURBO ... except maybe more of it"
xeler8 is offline   Reply With Quote
Old 12-01-2005, 07:14 AM   #5 (permalink)
Orlandoech's Avatar
ok got it done, thanks ppl!
Page generated in 0.14056 seconds with 13 queries
