Old 06-01-2009, 07:06 PM   #1 (permalink)
uturner's Avatar
Member Number: 13844
Default replace inner turn signals?
I searched for this but just ran out of time. I want to know how to replace the inner turn signals of the headlights for the MPX light bulb #3157.
you know, the amber ones that make the car look like a cross-eyed mule.... a really fast cross-eyed mule...
thanks
uturner is offline   Reply With Quote
Old 06-01-2009, 07:09 PM   #2 (permalink)
connsrt's Avatar
Member Number: 48865
Trader Rating: (130)
the easiest way is to just take the headlights out 2 10mm bolt for each headlights and 3 10 mm bolts on the bumper in between the headlights
SHE WILL BE MISSED
connsrt is offline   Reply With Quote
Old 06-01-2009, 08:30 PM   #3 (permalink)
uturner's Avatar
which bolts are on the bracket when I look on the top of the headlight housing? Are there any bolts under the headlight housing?
Old 06-01-2009, 08:59 PM   #4 (permalink)
wiggyx's Avatar
Member Number: 58107
Trader Rating: (52)
They're all on top and they're actually 8mm.
2 on each lamp, 3 on the bumper cover.
Old 06-02-2009, 02:40 AM   #5 (permalink)
uturner's Avatar
sorry but I only see two bolts that are the top brackets. I can't find the 3 on the bumper cover. Do you happen to have any pics?
Old 06-02-2009, 09:04 AM   #6 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
or you can reach under the bumper and access it that way
View Modifications
Old 06-02-2009, 09:16 AM   #7 (permalink)
wiggyx's Avatar
Trader Rating: (52)
They are right by the radiator. They help hold the front bumper cover onto the car.
Old 06-02-2009, 09:46 AM   #8 (permalink)
uturner's Avatar
And I need to remove those bolts to remove the whole headlight?
Old 06-02-2009, 11:58 AM   #9 (permalink)
wiggyx's Avatar
Trader Rating: (52)
Yup, cause you'll need to bend the bumper cover a bit to get the headlights out.
Old 06-02-2009, 08:26 PM   #10 (permalink)
uturner's Avatar
ok. Is this an easy replacement because that would really suck for $9 bulbs to require an extremely difficult installation.
I got another question: Are the clear side markers for turboneonstore, and the clear third rear light DOT rated?
Old 06-02-2009, 08:57 PM   #11 (permalink)
lphooper03's Avatar
Member Number: 37050
Yes...They are approved.
The install really is easy man...Just two bolts for each headlight...Then try to pull the thing out...You will see where it's getting stuck. The bumper overlaps onto the radiator support...So you disconnect the (3) 8mm bolts on the bumper cover and it will be allowed to flex. This will allow you to pull the headlight through.
50 Trim + Diablosport =
Old 06-02-2009, 09:06 PM   #12 (permalink)
Loyalty's Avatar
Member Number: 17771
Sometimes just grabbing a set of sockets and start pulling bolts out helps the learning process
Silver '03 SRT-4
Mods: Mopar Stage 1, HKS BOV, Mopar STS, Booger Bushings, K&N CAI, GReddy Oil Catch Can,
Hard IC pipes, AGP Wastegate, Dog Bone MM, MPx FMIC, short antenna, clear side markers,
MP strut tower bar, Rolled Rear Bumper
ICE: 7.5in Flip up CD/MP3/TV/DVD screen
Loyalty is offline   Reply With Quote
Old 06-02-2009, 10:02 PM   #13 (permalink)
wiggyx's Avatar
Trader Rating: (52)
Um, no they're not. DOT requires the front of the vehicle to have amber reflectors, not white/clear. The third brake light only has to emit red light, so it's fine.
Old 06-05-2009, 11:41 AM   #14 (permalink)
uturner's Avatar
Well, I was thinking of getting the clear corner signals with a silver bulb that brights up in amber. is that ok?
Old 06-07-2009, 02:36 AM   #15 (permalink)
uturner's Avatar
bump.
Page generated in 0.17775 seconds with 13 queries
