Old 09-14-2008, 11:39 PM   #1 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
Default Repairing broken Headlight tabs
Is it possible to repair broken headlight tabs? I'm thinking maybe if there was a donor...or something to that extent?
I have a set of black housings and both the tabs were "injured" in the accident rendering them un-bolt-up-able
Has anyone done this?
or 16 whatev
WTB: LCA bushings
Old 09-15-2008, 12:23 AM   #2 (permalink)
Member Number: 64215
you weld the tabs back on if you had a plastic welder and some donor tabs
BoostedBabe is offline   Reply With Quote
Old 09-16-2008, 07:13 AM   #3 (permalink)
redsoxsrt's Avatar
Member Number: 28768
Trader Rating: (51)
also you can go to home depot, superglue makes a special bonding agent for Hard plastics that are normally hard to glue togther. I dont have the info here but i might have it at home. I used it a few months ago, it worked great. its a little superglue tube of adhesive, and theres this little adhesion promoter thing too. the pastic that the headlight is made out of is one of those "hard to bond" plastics. not sure what it is, might be polypropelyne. but most glues say "bonds most plastics except bla bla bla" and 95% of the glues wont bond whatever the headlight is made of. I tried using the 2 part plastic weld from pepboys and it did nothing.
this will work
Plastic-Fuse - Super Glue Adhesive Products
Page generated in 0.12983 seconds with 13 queries
