Old 05-04-2005, 03:53 PM   #1 (permalink)
Member Number: 8107
Default Red gauges...
I installed my red LEDs (matrix) and they are not bright at all. In some spots theres no light... did i install them wrong, is there a certain way the bulb should facing or something? I got the brightest red bulbs too...
THE AN$WER is offline   Reply With Quote
Old 05-04-2005, 03:58 PM   #2 (permalink)
jacobsen23's Avatar
Member Number: 17081
Trader Rating: (10)
You probably installed them correctly. I have just heard that red doesn't work too well with our gauges.
jacobsen23 is offline   Reply With Quote
Old 05-05-2005, 08:37 PM   #3 (permalink)
E-BlueRocket's Avatar
Member Number: 11437
Trader Rating: (50)
ditto
No Boost... It Might Have A Button
E-BlueRocket is offline   Reply With Quote
Old 05-05-2005, 08:39 PM   #4 (permalink)
Member Number: 8107
hmm...
Old 05-05-2005, 09:41 PM   #5 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
Yup, I asked about this a few months back.
Old 05-05-2005, 10:04 PM   #6 (permalink)
dommo_g's Avatar
Member Number: 20279
I have also heard that the reds don't look very bright, but remember, LEDs are polarity sensitive. Just to be sure, double check that the bulb is inserted correctly. Most 194 LEDs will have one conductor marked red or such that you know it's the positive lead. Make sure you match that one up with the part of the green circuit board on your gauge panel that has the skinny trace. If you look at the bulb socket, you'll see where it makes contact on the green board after you twist it in. One of the traces on the board is skinny, this is the positive, and the other takes up most of the rest of the space around the bulb socket, this is the ground. Sorry, wish I had a close up pic to draw some arrows on, but I think you'll get it. My blues are not very bright, but just because I got cheap bulbs, I'm gonna post a pic in a couple of minutes.
dommo_g is offline   Reply With Quote
Old 05-06-2005, 12:45 AM   #7 (permalink)
Member Number: 8107
Oh ok, yeah i didnt know if there was a postive or what... damn now i gota take everything out again . Also, i got a bulb for my boost gauge, but i couldnt get the boost gauge bulb off the thing its on, like i tried twisting the bulb and it still wouldnt come off. Is there any trick way to get that bulb off without breaking it?
Old 05-06-2005, 12:48 AM   #8 (permalink)
SRTforums Veteran
Kustomatix's Avatar
Member Number: 18578
Trader Rating: (112)
wedge something in and pry the bulb out.
red most definately does not work. maybe if you take it all apart and take the green film out.. but i dunno..
Kustomatix is offline   Reply With Quote
Old 05-07-2005, 01:12 PM   #9 (permalink)
dommo_g's Avatar
I had a hard time getting my fat ass fingers in there, too. I used a pair of needle nose pliers to grab onto the socket and turn it out. Makes it a hell of a lot easier putting it back in, too. Good luck.
Old 05-07-2005, 01:32 PM   #10 (permalink)
Dark-SRT4's Avatar
Member Number: 7655
Trader Rating: (37)
you should've asked before you purchased. Red wont light up really anything except the needles and the redline.
Dark-SRT4 is offline   Reply With Quote
Old 05-08-2005, 08:56 PM   #11 (permalink)
z3roneo's Avatar
Member Number: 21351
Trader Rating: (35)
But would the inverted type leds work better and be brighter???
Boosted 2000 Dodge Neon....
2.4 Swap in the works...
z3roneo is offline   Reply With Quote
Old 05-08-2005, 09:02 PM   #12 (permalink)
Dark-SRT4's Avatar
Member Number: 7655
Trader Rating: (37)
no. i doubt any red led will work.
Old 05-08-2005, 11:49 PM   #13 (permalink)
dommo_g's Avatar
If you're REALLY determined to do this, try these CLICK ME!!
These are probably the brightest you'll get.
Old 05-10-2005, 09:06 AM   #14 (permalink)
Dark-SRT4's Avatar
Member Number: 7655
Trader Rating: (37)
no. those will not work.
give it up.
sry.
Old 05-10-2005, 04:43 PM   #15 (permalink)
Member Number: 10965
what about purple...i know ppl have done it, but no one's posted pics.
SRT-T3ddy is offline   Reply With Quote
Page generated in 0.20688 seconds with 13 queries
