Old 08-07-2006, 09:35 PM   #1 (permalink)
Member Number: 5048
Default quick ????
Hey guys, well today my driver side bulb stopped working. I have aftermarket bulbs that lasted me 3 years!! so im pretty happy but today it went out...
Funny thing is if I turn on my high beam, both side comes up so right now im driving with high beams so i dont get pulled over.
My question is, is the 9007 bulb include both low *** high? sorry if it's a stupid question cuz im used to changing both high *** low beams on other cars. Just want to make sure it's not a bad wiring or something.
Turb0 is offline   Reply With Quote
Old 08-07-2006, 10:43 PM   #2 (permalink)
URKRZE2's Avatar
Member Number: 32231
1. Swap bulbs to see if problem follows bulb or stays on driver's side.
2. Open driver's side door.
Remove panel on side of dash.
Check fuse #17 for an open.
3. Check wiring for fuse #17 (violet wire) for short or open.
4. Have mult-function switched analyized for failure.
One of those 4 should be it unless I missed something.
URKRZE2 is offline   Reply With Quote
Old 08-07-2006, 11:17 PM   #3 (permalink)
srtowner's Avatar
Member Number: 4573
Trader Rating: (78)
To answer your question yes it is one bulb for both high and low beams. There are two seperate elements inside the bulb and it is possiable for one to go bad and the other one still works. I mean you drive around mostly on low beam so they get the most use only makes sense it would blow first.
FOR ALL YOUR PERFORMANCE NEEDS
srtowner is offline   Reply With Quote
Page generated in 0.14253 seconds with 13 queries
