For the low beams,the outer screw on each side adjust vertical,the inner does horizontal.You also have to give the screw a bit of a turn to ge them to move.For the high beams I know the lower of the 3 three screw moves the light vertically.I'm gonna try the top two tomorrow.Dont use the blue clamps that are in the box to connect the wires.Also be careful when taking the lights in and out of the body.I cracked off on of the tabs that bolts onto the radiator support and had to get another one from MP.The replacement also has a small hairline crack in the same spot but I don't think it will be a problem.Make sure you use your old headlight gasket.
