Old 06-08-2009, 12:55 PM   #1 (permalink)
Member Number: 73326
Default Possibly starting another retro
So I've been wanting to do another retro for quite some time no. My first just isn't cutting it with me anymore, and after seeing many of them on this site I just can't take it anymore.
So my idea is to use the stock headlight/Depo with TL projectors. I plan for using the gatling shroud and possibly vacuum form too. What I would like to know is if anyone has any suggestions/ advise for your fellow retrofiter.
Some other quick questions too, would it be possible to fit a small HID projector in the turn signal spot (I've seen a picture of someone doing this on this forum but haven not found it again). Also will the lense from the DEPO headlight fit the stock OEM housing? Thanks for your time.
Matt
mcole254 is offline   Reply With Quote
Old 06-09-2009, 03:33 PM   #2 (permalink)
Remax Realtor's Avatar
Member Number: 3827
Trader Rating: (53)
You can fit a blazer projector or a bosch mini (I think thats the name) in the turn signal spot. However I can promise you it isnt going to do you really any good. Theres no benefit of it besides looks.
Not sure about the depo lens fitting. Your best bet is to just buy a new set of depos and work with those. THis way theres no guessing.
Fyi tls are great projectors. Im using them on a retro on my caliber srt-4. Im hoping to finish them by this weekend.
2003 srt-4 *totaled*
2001 neon r/t with srt swap *sold*
2009 dodge caliber srt-4
Old 06-09-2009, 07:24 PM   #3 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
unless you're using a single xenon projector, i wouldn't worry about using a projector for the turn sigs. the guy who was doing that was going to use it as a halogen highbeam. i would image, length wise, there would be issues.
be very careful w/ the vacuforming. for some reason lately every sheet of acrylic i've heated have bubbled up, and the only fix for that would be bondo (i hate sanding).
View Modifications
Old 06-09-2009, 09:01 PM   #4 (permalink)
Ya as far as a second projector I've decided against it. I may try a turnsignal projector like this > LittoDeviL Design Group - 2006 Infiniti G35 Sedan Quad HID Projector, LED Projector Turn Signal (for some reason I can't insert a hyperlink?). With the housing I'm probably going to stick with OEM parts, that way there is no question about quality and fit. I just bought the TL's today hopefully everything goes will on that end.
Old 06-10-2009, 08:27 PM   #5 (permalink)
wiggyx's Avatar
Member Number: 58107
Trader Rating: (53)
^^^ That seems like massive overkill to me. But I'm sure it would look nice.
wiggyx is online now   Reply With Quote
Old 06-11-2009, 09:35 AM   #6 (permalink)
Which part, the heat sinks or the whole thing in genrel, cuz I don't think I would go quite that far with the heat sinks,, I just thing the projector lens looks sick in the turn housing.
Old 06-11-2009, 10:52 AM   #7 (permalink)
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (50)
Actually those heatsinks are totally needed when using those high powered led's. Their #1 enemy is heat. Remember in a housing, there's little to no airflow & they can produce a lot of heat & die if you don't heatsink them correctly.
John Ruckman
Stage 3 with all the goodies
See My Ride
ND4SPD DESIGNS
Old 06-11-2009, 10:57 AM   #8 (permalink)
wiggyx's Avatar
Trader Rating: (53)
I meant that the whole projector signal would be overkill. No doubt it would look mean as hell though.
Old 06-11-2009, 02:29 PM   #9 (permalink)
I've been trying to research the cooling aspect of the led, I'm thinking of doing someting that it would be hard to mount all of them to a single heatsink, do you think a fan (like one in a computer) blowing or pulling air across the heat slug on them would work. The following link has diagrams LUXEON K2 and LUXEON K2 with TFFC LEDs :: High Power LEDs
Old 06-11-2009, 08:04 PM   #10 (permalink)
Member Number: 3827
Trader Rating: (53)
Why go with hi power leds? Do you just want the look of leds, or are you trying to make led flashlights? Personally I would just use some superflux or a similar led.
Old 06-11-2009, 09:33 PM   #11 (permalink)
Just FYI audi's DLR's use those exact leds
Old 06-12-2009, 11:02 AM   #12 (permalink)
lphooper03's Avatar
Member Number: 37050
and we all know those look like sex.
50 Trim + Diablosport =
Old 06-18-2009, 01:13 PM   #13 (permalink)
Ok so I just go my gatling shrouds like 5 mins ago. For them to fit on the TL projector do I need to cut the inside part that clamps on the projector? I will be posting pictures when I'm a little further in my progress.
Matt
Old 06-18-2009, 04:21 PM   #14 (permalink)
Member Number: 3827
Trader Rating: (53)
You will probably have to cut the bottom to clear the selenoid. Thats the bad part about tls is the damn selenoid is in the way. Take some pics and we can better help you. ARe the gatling guns 2.5" or 3"? If they are 2.5" they will need to be opened up a little.
Old 06-18-2009, 05:15 PM   #15 (permalink)
aww sheet's Avatar
Trader Rating: (31)
once he cuts away the inner portion of the shroud, it'll be 3"
Page generated in 0.19202 seconds with 13 queries
