Old 10-16-2005, 07:12 PM   #1 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
Default Pics of what my relayed harness looks like
BTW, Jimmy this one is yours!
Here it is laid all out....
Old 10-16-2005, 09:36 PM   #2 (permalink)
Toofpaste39's Avatar
Member Number: 17599
Trader Rating: (24)
Check your PM's. Will mine look like that?
Toofpaste39 is offline   Reply With Quote
Old 10-18-2005, 05:24 PM   #3 (permalink)
Member Number: 12903
thats a quality piece. thumbs up for quality. how much differenct would you setup the wires for a hi/low hid setup? and what would you charge?
red2k2rt is offline   Reply With Quote
Old 10-18-2005, 07:57 PM   #4 (permalink)
Member Number: 17495
Hak,
(All this is said with my tail between my legs because I was a dick to you last time I posted in one of your threads and now respect you as God of HID lighting )
I have wired up a very similar setup for my HIDs, and was wondering how it would work if I diode isolated the high and low beam wires and connected both to pin 85 on the realys. (in order to avoid a restrike if and when I accidently hit the switch.)
Think this would work? Any downside I may not be considering?
Quote: Originally Posted by srt-4 Banger
i took my car in yesterday for the regular warranty and everything and i said fuck why dont u guys put it on they wanted to charge me way to mu ch so im gonna try to do it myself any suggestions or help u guys can give me
UncleMunz is offline   Reply With Quote
Old 10-18-2005, 09:40 PM   #5 (permalink)
Member Number: 17930
Trader Rating: (58)
I used 2 relays just to be safe one for each side.
2004 E.Blue Srt-4*SOLD*
2002 Acura Rsx Type-S *SOLD*
2003 Mini Cooper S *Current*
04pshhh is offline   Reply With Quote
Old 10-19-2005, 07:19 AM   #6 (permalink)
haknslash's Avatar
Quote: Originally Posted by UncleMunz
Hak,
No problem man. I hold no grudges.
Anyways, to fix your fear of accidental restrike all you need to really do is place a diode in between the low beam wire and the high beam wire. Like so...
However, this is a warning, should you ever place your halogen or stock bulbs back in, you MUST remove this diode or else it will cause both filaments to be on once you hit highbeams and the stock electrical system will overload thus blowing the high beam circuit fuse constantly.
Old 10-19-2005, 07:38 AM   #7 (permalink)
Trader Rating: (24)
Can I paypal you today for that harness?
Old 10-20-2005, 10:09 PM   #8 (permalink)
SRToc Member
jimmyssrt's Avatar
Member Number: 2544
Trader Rating: (32)
thanks ! ! !
SWEET ! ! ! Thanks hak' BTW my Hella Gen 3s will be here after the weekend, just in time for your harnesses to arrive. Your set-up is a lot nicer, more professional looking than mine, with all the wire loom. I've got a bunch of zipties, otherwise, same in design; of course it was designed from your diagram, but yours has a better quality relay; which I couldn't find anywhere... (Bosch or AAMP)
If I had an analogy to describe an HID retro, it would be akin to going from dial-up internet to cable/fiber internet. it's that much of difference in lighting. I'm soooo glad I took the plunge into this retro project, my eyes thank me for it.
jimmyssrt is offline   Reply With Quote
Old 10-21-2005, 12:47 AM   #9 (permalink)
killervenom's Avatar
Member Number: 14572
ok now i know i asked but never got a very clear answer the diode leaves the ballasts on when you switch to high beams but were does the red wire from the TL's bi-xenon projector go. To the red wire in the 9007 connector on the car, right?
Current Mods : Psi-Fi CAI, MSD 8.5 MM Wires, Mpx Heat Shield, DC Front & Rear Strut Bars, Mopar STS, Booger Bushings, JLM Motor Mount's, AGP Race FMIC, JBM Hard Pipes, Billet Check Valve, TL retrofit projectors, Mpx UDP, SRT Oil Press., Pyrometer, LFS Fuel Rail, AEM UEGO
***ALL FOR SALE*** PM ME OR EMAIL
killervenom is offline   Reply With Quote
Old 10-21-2005, 08:05 AM   #10 (permalink)
SRToc Member
jimmyssrt's Avatar
Member Number: 2544
Trader Rating: (32)
Thumbs up
yes, that is correct.
Old 10-22-2005, 11:47 PM   #11 (permalink)
but the 12v power from the 9007 to the motor is constant right. what happens once the tl's actuator opens all the way does some thing sense it and cut the power at the actuator. reason i ask is i dont want to burn up the motor/actuator.
Old 10-23-2005, 12:07 AM   #12 (permalink)
SRToc Member
jimmyssrt's Avatar
Member Number: 2544
Trader Rating: (32)
it's not a motor, it's an electro-magnet that lifts the shield; no worries with burning it out.
Old 10-23-2005, 11:26 AM   #13 (permalink)
Sriquixotic's Avatar
Member Number: 13225
should i get this if i plan on getting darksydes 4300k hid kit? thanks
Sriquixotic is offline   Reply With Quote
Old 10-23-2005, 12:36 PM   #14 (permalink)
haknslash's Avatar
No, its only activiated when you press the highbeams [ON]. Think of it just like how your car works now. When you flip on for highbeams, THEN the solenoid for shield operates and moves the lowbeam shield out of the the way to expose the high beam shield. It is not being fed consistant power at all times unless of course your had the high beams on at all times.
I recommend this to anyone who is upgrading their stock lighting wether it be from a high wattage halogen bulb or HID to aftermarket fog lights.
I know the bling lights kit (same kits dark syde sells) comes with a harness but it is a "plug and play" harness which all it does is basically connect the stock 9007 plug into a plug on a harness that connects to the ballasts. Judging from what I've seen on that harness it still utilizes the stock wiring 100% and does not safeguard your electrical system should a issue occure.
Old 10-26-2005, 10:46 PM   #15 (permalink)
Trader Rating: (24)
^ Did you mail out the harness?
