Old 02-27-2008, 11:57 PM   #1 (permalink)
Stealth's Avatar
Member Number: 742
Default Passanger Side parking light won't turn on! BLINKER WORKS THOUGH!!>?!?!
Okay..I tried posting this in the problem section but no one answered..
My Passenger side parking light (Turn Signal) Does NOT turn on when
the parking lights are on. It will however blink if i use the turn signal or
hazards.
Any ideas?
I've tried replacing the bulb and still no fix.
Is there a fuse?
Thanks.
Stealth is offline   Reply With Quote
Old 02-28-2008, 12:32 AM   #2 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (32)
check the wires. if the fuse was an issue then it wouldnt light up at all.
04 NSRT-4 - DBB 50T Daily Driver
87 Mustang GT - New project..working on getting a big snail..
Old 02-28-2008, 11:38 AM   #3 (permalink)
haknslash's Avatar
Member Number: 21686
Check your MFS? Also check the connector to make sure the wiring is fine (frayed, burnt, etc) and no corrosion building up inside it. Your parking light gets 3 inputs IIRC. One for ground, one for parking "steady" light and another for the turn signal. The parking and turn signal wires both go to their own filament inside the bulb. If one is working and the other isn't, usualy it's because it's not getting power somehow. Use a multimeter or test light and make sure you're getting power to the parking light connector for the parking steady light. If you aren't getting power, then follow the path until you find your problem. Hopefully it's just corrosion or a cut wire and not your MFS and wiring all together.
Old 02-28-2008, 01:22 PM   #4 (permalink)
darthcual's Avatar
Member Number: 36035
Trader Rating: (29)
Good lord ppl its the filament in the bulb. Dual filament. The parking light part of the filament is broke, buy a new bulb.
Edit just saw that you replaced the bulb. Check the replacement. It might have broken when you put it back into the headlight assembly. Happens alllllllll the time.
Quote: Originally Posted by Madrex View Post
the internet has ruined me...stills will not do it...has to be video...nasty video
darthcual is offline   Reply With Quote
Old 02-28-2008, 04:19 PM   #5 (permalink)
Stealth's Avatar
Member Number: 742
I'm pretty sure I tried to voltage awhile ago and I wasn't getting anything.
Thats why I thought it might be a fuse or what not.
Whats the MFS????
Old 02-28-2008, 08:42 PM   #6 (permalink)
stage3matt's Avatar
Member Number: 54658
multifunction switch. the one controlling headlights, p-lights, fogs, and directionals.
that thing coming off of the left side of the column
2009 1320x threads:
III
stage3matt is offline   Reply With Quote
Old 02-28-2008, 09:39 PM   #7 (permalink)
Stealth's Avatar
Member Number: 742
How much does that go for
Old 02-29-2008, 06:35 PM   #8 (permalink)
haknslash's Avatar
Just like this happens all the time with Dodge vehicles....
Fire in the Dash!!!!!
Old 02-29-2008, 11:21 PM   #9 (permalink)
Trader Rating: (32)
thats happened more often to those who use the fogs all the time right? ( i no longer have mine lol )
Old 03-02-2008, 07:14 PM   #10 (permalink)
darthcual's Avatar
Trader Rating: (29)
Yes. Usually when that happens, nothing works.
Old 03-03-2008, 10:29 AM   #11 (permalink)
haknslash's Avatar
Not necessarily caused by fogs. Dodge/Jeep/etc has a long history of MFS failures. Why they continue to build their electrical systems around such BS is beyond me.
Old 03-03-2008, 11:40 AM   #12 (permalink)
Trader Rating: (32)
^ok well guess i only cut down part of my possibility then lol.
Old 06-04-2008, 09:35 PM   #13 (permalink)
Stealth's Avatar
Member Number: 742
Ugh it looked just like that except 1000x worse.
I bought the rewiring kit...do i need the MFS side also???
bah...never going to buy a dodge again
Old 06-11-2008, 12:28 AM   #14 (permalink)
gq4life's Avatar
Member Number: 10297
im calling dodge tomorrow.. i worked for them.. ive bought 4 brand new dodge.. last 4 cars.. been loyal dodge guy.. i understand things going wrong.. but my whole dash burning.. i cant fix.. im a poor soldier with minus $10,000 to his name not counting car loan.. electrical fire is bullshit.. i read that the paper work on this from dodge.. they dont care because no one has gotten injuried or died..
http://nhthqnwws112.odi.nhtsa.dot.go...028-24982P.PDF
i should take one for the team..
put car back to stock.. sit it and it and drive it till it goes up in flames.. and get all burnt and sue..
get everyone of the people with this same problem in court
Page generated in 0.73053 seconds with 13 queries
