Old 01-05-2007, 11:47 AM   #1 (permalink)
SRTchild's Avatar
Member Number: 32169
Default Parking Light Bulbs
Where can i find some good led bulbs for the parking light. I want them in white. I want bulbs that will last and not blow out like some of ya'lls leds have. any suggestions? I think the size is 3157, thanks
Aem CAI, Agp WGA, Stage 1, Ndswngs V6, MPx BFIMC, Aeroforce Scangauge, AEM EUGO, MPx Dual Gauge Pods, Yellow Foglight Bulbs, Laminx, Bdjs Shorty Antenna, Eibach Pro Kit, Prothane Endlinks, ESMM, 20% Tint, PTP Coil HS, Taylor Wires, NGK 4306s, $20 Catch Can, Mopar Front Badge, SRT-4 V2 Badge, PTP Check Valve, ED Blitzz TT, TurboSmart MBC, Rota Slipstreams, Bridgestone Potenza RE-01 R's
SRTchild is offline   Reply With Quote
Old 01-05-2007, 01:18 PM   #2 (permalink)
SRT-4Store.com's Avatar
Member Number: 49032
Trader Rating: (18)
i'm workin on something for this, but it requires that you have depo headlights... what i'm making is designed to sit in the back of the reflector, using wide angle led's, so obviously just inserting them through the hole isnt gonna happen...
mainly they're going to be an option for FYX193's retro's, but anyone with depo's can use them really...
SRT-4Store.com is offline   Reply With Quote
Old 01-05-2007, 02:24 PM   #3 (permalink)
VampOfVegas's Avatar
Member Number: 38215
Trader Rating: (67)
LEDS in headlights will fail due to heat. There might be some out there that will work (I havnt tried any).
I got my blue ones from Wal-Mart. When off they are blue, then on they are white (not blue).
The Vampire Light Seller.. Guy.
VampOfVegas is offline   Reply With Quote
Old 01-05-2007, 04:25 PM   #4 (permalink)
Trader Rating: (18)
correction, led's there wont fail...
there's not enough heat there for them to get hot...
i had led's right under the headlight bulb to make my headlights glow blue...they lasted for years until i got in a front end wreck and one of the housings had to be replaced(so i just cut the wire going to the other one...)
led turn signals will be fine...
Old 01-05-2007, 05:36 PM   #5 (permalink)
Trader Rating: (67)
good to know, Hyundai was a different issue and a few honduhs.
Page generated in 0.17236 seconds with 13 queries
