Old 09-29-2009, 08:50 PM   #1 (permalink)
Member Number: 46111
Trader Rating: (13)
Default Ok So i got NO fog lights coming on...?!?!?
Ok so i started to head back up to school after a weekend home. I had to pass some really dark places and used my high beams.. well when it comes on it takes off the fogs.. right? So i switched it a couple of times.. when im pulling up to my apartment i see reflection of my lights but no fogs but my green fog indicator light is on inside. Im not good with electrical. But honestly this week has been hell, 1st the TPS sensor then a new battery and now this... Kickin rocks right now.
Where do i start? What should i check?
Ive searched but most people have no indicator lights and that means keyless sensor module.. this is not my case.
Split an eighth of shrooms just so i can see the universe
280hp 323tq
Exhaust Depot SEE with Maxx Fab DP, Turbo XS FMIC,
E/D Hardpipes with HKS SSQ Purp Tops,Koyo Radiator,
AEM Intake,Checkvalve, Agp with ptp spring Set 20/16
SAFC NEO tuned by Pablo
WTB FUEL PUMP , Rewire, Wideband
BoostinByeU is offline   Reply With Quote
Old 09-29-2009, 09:36 PM   #2 (permalink)
TenSix's Avatar
Member Number: 30687
Trader Rating: (13)
I had both foglight bulbs go at once before. Try checking the fuze and then the bulbs.
TenSix is offline   Reply With Quote
Old 09-30-2009, 02:18 AM   #3 (permalink)
BI_SRT-4's Avatar
Member Number: 45892
I have had only 1 foglight working for over a year.
Are there individual fuses for each one?
The bulb is brand new and i checked it with 2 new bulbs.
Still nothing. Some shoot me in the right direction?
Sorry for hi-jacking but in kinda in the same boat as u.
Srt-4 04 E-Blue, R/C 750cc Injectors, Walbro 255 lph, Devils Own M/I M5 Nozzle, 3" Turbo back Side exit exhaust, AEM wideband, Apexi S-AFC NEO, CCA FMIC 12"x24"x3", AGP hard pipes. Upper and Lower W/ Greddy Type-S BOV
Turbonetics 54-Trim
Tial 38 MM Wastegate
Xtreme Boost Manifold
20 psi
???WHP/???WTQ
Bad Influence Auto Squad
BI_SRT-4 is offline   Reply With Quote
Old 09-30-2009, 07:20 AM   #4 (permalink)
SRT of the Month
LilSparkPlug's Avatar
Member Number: 17636
Trader Rating: (70)
In the in car PDC there are two fuses, one for each fog light, and then two more, one for each headlight. Check those first. Are you running factory bulbs or higher wattage bulbs? If you're running higher wattage bulbs check the harness to be sure it hasn't melted. If all of that checks out normal, remove the steering column cover and check out your Multi Function switch. If the plug is melted the switch is more than likely fried.
Old 10-01-2009, 12:04 AM   #5 (permalink)
BI_SRT-4's Avatar
My MFS is a little messed up but 1 still works.
Where are these fuses you want me to check?
I only see 1 fuse in the inside panel.
Under the hood there is no fog light fuses, well atleast none marked.
I see that there are 2 fuses for the head lights but not for the fog lights.
I just picked up the wiring diagrham and it only shows 1 fog light fuses.
Hope someone can help casue i haven't had fogs in over a year.
Old 10-01-2009, 12:38 AM   #6 (permalink)
Member Number: 71225
^ thread jacked
AnsareStg0 is offline   Reply With Quote
Page generated in 0.14452 seconds with 13 queries
