Old 02-01-2005, 05:53 PM   #1 (permalink)
MILK's Avatar
Member Number: 14121
Default Neon underbody kit?
i have been thinking getin the streetglow goldseries.
i am a noob and when it comes to lighting and electrical stuff i get really confused, if some one could tell me how to install a neon kit it would be help full, or a website that tells you how to.
MILK is offline   Reply With Quote
Old 02-01-2005, 05:59 PM   #2 (permalink)
iupui1299's Avatar
Member Number: 2187
Trader Rating: (12)
Check out oznium.com
iupui1299 is offline   Reply With Quote
Old 02-01-2005, 06:08 PM   #3 (permalink)
Member Number: 2051
Trader Rating: (32)
Agreed... Phil is a good guy. I got two plasmaglow kits from him.
`````````(o o)
,--ooO-----(_)-----------,
| ``````E-FIGHTS```````|
| ````````ARE``````````l
| ``````HILARIOUS``````|
| `````````````````````l
'--------------Ooo-------'
````````|__|__|
````````ooO Ooo
ContraAl is offline   Reply With Quote
Old 02-01-2005, 06:12 PM   #4 (permalink)
iupui1299's Avatar
Member Number: 2187
Trader Rating: (12)
Phil has his own line of LED underbody kits called flowlighting.....it's brighter than streetglow's LED kit..I don't know about the neon kit. He sells them on his site along with the grand daddy of all kits the Iceled kit but that's 800 bucks!!
Old 02-01-2005, 09:58 PM   #5 (permalink)
MILK's Avatar
i looked at them but the red is to bright it almost looks pink, i wnat like a darker red
Old 02-02-2005, 07:41 PM   #6 (permalink)
iupui1299's Avatar
Member Number: 2187
Trader Rating: (12)
I have teh flowlighting kit...the red is red. Picture might make it look pink but it's definetly red.
Old 02-03-2005, 09:55 AM   #7 (permalink)
MILK's Avatar
yeah but a lot of people said that i looks to pink, i guess i will just have to try it and if i dont like it re-sell to some one
Old 02-03-2005, 10:46 AM   #8 (permalink)
hydrohopper's Avatar
Member Number: 11900
Trader Rating: (38)
I purchased the Streetglow Gold Series. Only paid $130 including shipping, and brand new. I installed them and they look really good. I got red. Few things to look out for:
1. On the side under the car you have the body lip. You should places the tubes behind the lip. If you put it in front of you the lip you can see the bulbs as you go down the road. If you put the tubes behind the lip you can't see the bulbs but the lights doesn't spread out as much. To me I don't want to see the bulbs.
2. Transformer mounting. You probably already noticed that their isn't a lot of room under the hood for mounting the transformer. Most people look for places under the hood to mount. I mounted mine on the drivers side near where the stock fog lights are. Their is a huge metal plate that you can drill into to mount the box.
3. Wiring. Wiring the switch through the firewall is probably the hardest part of the installation. Dodge doesn't give us much room to play around when adding new wiring. The best place that I found is, on the drivers side located near the steering column is a normal size boost that goes through the firewall. I just cut a small slit through the boost and pushed the wire through.
If I can figure out how to post pics I will put them on the forum. Installation took about 1.5 hours.
http://underground.jreams.com
Mopar Stage 3R with Toys
2004 Flame Red SRT-4
Turbocharged 2.4L DOHC I4 HO
hydrohopper is offline   Reply With Quote
Old 02-15-2005, 01:19 PM   #9 (permalink)
vypurr2's Avatar
Member Number: 10185
NO NO NO!!! You did it the HARD way. Here is how to easily install your neons.
1) Mount and drill all holes in the side flares, front lip, and in the rear (remember, higher in the body = better)
2) Lift your windshield wipers
3) Unscrew the 3 or 4 bolts holding that plastic trim below the windshield
4) Remove the plastic trim
5) Inside, you will see a mesh grill with a hold behind it
6) Simply buy the strong carpender foam double sided tape, and secure your transformer here. (passenger side)
7) Remove your dashboard by removing the 4 screws, and both pillars (these pull off, but be careful)
8) Under the dash cover, you will see a plastic tube in the center (this is the front defroster).
9) from the inside, run a clothes hanger down along side the plastic tube until you are able to pull it out thru the grill under the hood mentioned in step 8. 10) Attach the 2 wires that you will use for your switch to the hanger, and pull it through
11) Place the switch wherever u want (I put mine in the glove box).
12) be sure to pull the wire fairly tight, and use lots of electric tape to assure that it will hold the wires in place.
13) Run all wires from the light tubes to the transformer (avoid placing these near the exhaust, they WILL melt)
14) Screw all 8 wires into the transformer
15) Attach your gound from the transfomer to any of the nearby grounds
16) now, pull your hot/live/red wire all the way accross the front to the drivers side, and allow it to run behind the wiper assembly. You will be able to pull it down and to the side, and connect this inside the fuse box (DON'T FORGET THE FUSE THEY GIVE YOU!!!)
17) Reconnect and attach all parts, and enjoy.
I will take some pics, and can help u if u need!
vypurr2 is offline   Reply With Quote
Old 02-15-2005, 05:48 PM   #10 (permalink)
Member Number: 10879
check out www.dontberice.com...this isn't 2f2f my friend. underbody lights = homosexual.
'04 SRT-4 | Stage 1 | AGP RACE FMIC | Exhaust Depot 3" w/ O2 housing | AGP WGA | Greddy Turbo Timer | Greddy EBC | Boomba MM's | MSD 8.5's | NGK Iridiums | Turbonetics UPP w/ Raptor BOV | K&N Drop-In | Powerslot Front Rotors | Maddog 58% STS
Cheebahawk is offline   Reply With Quote
Old 02-15-2005, 05:58 PM   #11 (permalink)
vypurr2's Avatar
Oh. I am sorry that you don't fit in around here.
WHY THE FUCK DO YOU EVEN BOTHER READING THIS AND POSTING THAT??
Do you think that we will read your post, and then say "holy shit, that asshat is right. I should go rip those lights off of my car because they are a POS"?
I hate to tell you buddy, but the neon lights are here to stay. I dont care who you ask.
Why do I put them on? Hmmm....I am the only car that "I" have ever seen within an hour of my house with them on. Chics LOVE them. Oh yeh, a chic is a woman. You probably wouldn't know about that though...
Seriously, GO GET A LIFE. You are worse than the ppl who put mismatched body kits on their cars.
We are all on this forum for the same reason, because we enjoy cars. WHO CARES IF MY CAR HAS NEONS UNDER IT?
Old 02-15-2005, 06:21 PM   #12 (permalink)
iupui1299's Avatar
Member Number: 2187
Trader Rating: (12)
Oh crap! Somebody tell my wife for me! I never knew I was gay ...wait my wife likes them too...does that make her gay? Your nuts dude....get a life.
Old 02-15-2005, 06:41 PM   #13 (permalink)
DJOrtiz's Avatar
Member Number: 17860
Trader Rating: (26)
vypurr has some spunk!!! but i F*CKING AGREE WITH HIM... I THINK THEY ARE COOL ALSO, SO GO SUX AN EGG....
no but seriously broh.. everyone has their own opinion and if you didnt like them then you didnt have to read this threaded..
~DJ and JPG for JR. Mods 09~
loved by peteblksrt4
DJOrtiz is offline   Reply With Quote
Old 02-18-2005, 10:49 PM   #14 (permalink)
Member Number: 14764
gay
they stopped recruiting for 2f2f bro
iwant1ne is offline   Reply With Quote
Old 02-18-2005, 11:10 PM   #15 (permalink)
vypurr2's Avatar
O. Are you serious? I had no idea. I guess I will have to ship my ICE-LED Kit back now. Damn, I really wanted to be in that movie too!
Guess I will have to go back to living my life 1 16sec 1/4 mile at a time!
Page generated in 0.22665 seconds with 13 queries
