Old 11-29-2008, 04:10 PM   #1 (permalink)
dragradial's Avatar
Member Number: 22291
Trader Rating: (13)
Default Need New Replacement Fog Light Bulbs Any Good One?
One of my fog light bulbs burnt out did a search and a lot of people have had problem with silver stars. Any input, I have stock lights thinking about also getting the head light bulbs. Just looking for good visibility.
dragradial is offline   Reply With Quote
Old 11-30-2008, 12:12 PM   #2 (permalink)
dragradial's Avatar
Trader Rating: (13)
I heard Phillips cam out with X-treme power bulbs that are a lot brighter than other brands ,but I am having a hard time finding who sells them and if they make them for our cars.
Old 12-03-2008, 10:54 AM   #3 (permalink)
duster360's Avatar
Member Number: 45182
Stock are 25W-35W(i forget) I picked ones off the shelf that had the same connector shape but were 55w. They were no more expensive than the stock ones.
Sorry I forget the part #.
A good general LOW COST improvement for all cars is to ensure that there is full battery voltage getting to the headlights. By the time the voltage goes into the car, through the dimmer/headlight switch and then all the way back to the bulbs, the voltage can be as low as 10v-11v. Splicing in a relay, similiar to the fuel pump rewire mod, REALLY brightens the lights. NO fancy and expensive bulbs needed!
I haven't yet did this on the SRT, but I did on my last car(98 Neon). I had only 11.3V getting to the bulbs. After I rewired it, there was only a .2v drop from the battery voltage(13.1V!!). Let me tell you 2 extra volts really brightens things up! The headlights were noticably brighter and the light color changed to a crisper white vs the standard halogen "yellow"
Old 12-03-2008, 11:40 PM   #4 (permalink)
Milkit18's Avatar
Member Number: 46113
Trader Rating: (23)
nokya yellow .. bulb type 880
Milkit18 is offline   Reply With Quote
Page generated in 0.15131 seconds with 13 queries
