Old 04-16-2008, 12:15 PM   #1 (permalink)
2005 RED SRT-4's Avatar
Member Number: 35073
Trader Rating: (36)
Default Need a lighting GURU's opinion
I just ordered an HID kit (10K) from VVME.com. I was planning on ordering the Modernperformance projector housings to put them in, however I ordered 9007 HIDs and the projectors are H1s. So my question to you is what you do? Should I just run the HIDs in the stock housings or should I sell the HIDs and buy H1 and the projectors? Is there someone who can make a projector housing headlight that will take the 9007 HIDs for fairly cheap? Give me your honest opinions guys.
Thanks,
Nate
2005 RED SRT-4 is online now   Reply With Quote
Old 04-16-2008, 12:28 PM   #2 (permalink)
OrionR12's Avatar
Member Number: 21193
Trader Rating: (128)
Thanks,
Nate
I had 9007 HID's before I bought the modern lights and I just bought a set of H1 bulbs and they plugged into the 9007 ballast. I think most standard HID kits have the same plugs.
-ryan-
'04 eBlue SRT-4 (soon to be Stg.3!)
Proud Supporter of DARKSYDE Innovations
In memory of Steven Nightshade Lorenz
My Stage 3 experience - click here for more details
OrionR12 is offline   Reply With Quote
Old 04-16-2008, 12:30 PM   #3 (permalink)
Trader Rating: (36)
Nice, appreciate the quick response. Anyone else have any good ideas?
Old 04-16-2008, 01:09 PM   #4 (permalink)
rasp's Avatar
Member Number: 56076
Yeah, don't expect good light output with 10k.
Old 04-16-2008, 01:34 PM   #5 (permalink)
OrionR12's Avatar
I had 10k and they were CRAZY bright...when I switched to retros I went with the 4300k and have been VERY happy with the change!
Old 04-16-2008, 01:59 PM   #6 (permalink)
wiggyx's Avatar
Member Number: 58107
Trader Rating: (34)
I'd skip the cheap-o projectors and just use the stockers or find a set of retro's (although that's an expensive option).
Old 04-16-2008, 02:07 PM   #7 (permalink)
OrionR12's Avatar
I am on my 3rd set of retros due to condensation problems
I did see someone got the Modern projectors and swapped out the projector w/ another and the light output was 100x better!
Old 04-16-2008, 02:45 PM   #8 (permalink)
morgantj13's Avatar
Member Number: 47175
that was me...ya, the light output is 100x better than stock(stock headlights or prjectors), but doing a retrofit on them wasnt very easy, i had to hack a LOT out of the headlight to make projectors(e46) fit. Other projectors might not need that much taken out, but it is do-able. here is the thread where milikit and I post photos and stuff of the halo retrofit
Old 04-16-2008, 02:54 PM   #9 (permalink)
Trader Rating: (36)
I would like to do a set of retro's but don't want the hassle's that come with them. I may just try the stockers and see how they look. The only thing I am affraid of is the cops nailing me for being toooo bright. IDK we'll see what happens when they get here!!! Thanks for all the info guys, it's greatly appreciated.
Old 04-16-2008, 03:14 PM   #10 (permalink)
OrionR12's Avatar
Yep you guys are who I was referring too...BIG props to both you guys for being the first to do it!
I am on my 3rd set of BoostJunkies retros due to condensation...if I can't get these to work out I might be going the same route as both you guys.
Old 04-17-2008, 08:24 AM   #11 (permalink)
SRToc Member
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (30)
I'll just about bet everything I love that you're getting leakage from the turn signal gasket/ area. Very common on all depo/ eagle eye headlights regardless if they're brand new or have been opened up.
John Ruckman
- Stage 3 W/ Toys
- AGP WGA, Race FMIC & 3" Intake
- Custom Magnaflow Exhaust & O2
- Eibach Prokit
- B-Woody Traction Bars
- ND Performance Traction Control System
See My Ride Here
-ND4SPD- is online now   Reply With Quote
Old 04-17-2008, 09:29 AM   #12 (permalink)
OrionR12's Avatar
I am using the stock signal and gasket to prevent any leakage...When I sealed up the outside even more it drastically changed the condensation problem...I am up to 1 week with now leakage. That is with some rain and a car wash.
Old 04-17-2008, 06:54 PM   #13 (permalink)
Trader Rating: (36)
What do his retro's go for if you buy just the headlight unit itself, not including the HIDs (since I already have some comming!!)? I may look into a set of those if they are reasonable and just seal the shit out of them before I install them.
Old 04-17-2008, 07:00 PM   #14 (permalink)
OrionR12's Avatar
somewhere between 600-900. Depends if you want to TSX (only low beam) or the TL (both low and high)
Old 04-17-2008, 08:20 PM   #15 (permalink)
rasp's Avatar
SUPER BRIGHT LEDS home
^^ Every light you ever need, at good prices and fast shipping. I can even get them bulk shipped at a much lower cost since I'm pals with the owner.
Tried one of ByVamps kits...and just fucking
