Old 10-16-2005, 12:16 PM   #1 (permalink)
turbotrix2004's Avatar
Member Number: 20760
Trader Rating: (41)
Default need help with wiring lights
anybody know how to wire a single filament bulb to stay on with parking lights and blink when the blinker is on
turbotrix2004 is offline   Reply With Quote
Old 10-16-2005, 12:27 PM   #2 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
Depending on the car.......you might can by with tying the postivie wire into the postitive wire on the parking lamp and then tie the other wire from the single filament bulb into the wire that allows the parking light to blink. That wire should stay ground until you make it "flash".
This is usually how you make sidemarker lights stay on like parking lights and then flash when you hit the turn signals.
I'll have to play around with our wiring to give you a precise answer.
Old 10-17-2005, 05:56 PM   #3 (permalink)
Trader Rating: (41)
yeah i thought about that also but at night when the parking lights are on i don't think the blinker would work it would just stay lit being that there is constant power from parking lights going to it
Old 10-17-2005, 10:34 PM   #4 (permalink)
Member Number: 12903
it would blink cause everytime the relay turned on the power the light would loose its ground and turn off.
red2k2rt is offline   Reply With Quote
Old 10-18-2005, 05:45 PM   #5 (permalink)
Trader Rating: (41)
ok thanx then i'll give that a try and see what happens
Page generated in 0.18460 seconds with 13 queries
