Old 04-02-2008, 08:36 PM   #1 (permalink)
redsrtfour's Avatar
Member Number: 56204
Trader Rating: (13)
Default need help fuse blowing
ok my tail light fuse keeps blowing on me but my stop lights still work and hey are on the same bulb so i dont know what it is. thanks for the time and help dont have any instrument panel lights or tail lights (although the brake lights work when pressed down) and signal lights work fine too
redsrtfour is offline   Reply With Quote
Old 04-04-2008, 06:05 PM   #2 (permalink)
MoparLuva's Avatar
Member Number: 50259
Hey Man, That Happened To Me Too, If I Was U, I Would Check The Wiring In The Steering Colulm Box And See If Anything Looks Weird Or Different Cuz, To Me It Sounds Like A Short To Me
Quote: Originally Posted by kortERHorse_281 View Post
i usually leave my negative terminal off for about 30 minutes...unhook it, go watch a little porn, clean up the mess you make and then go back outside and connect the battery...
Shooting For 300whp In The Next Few weeks On Stock Turbo
MoparLuva is offline   Reply With Quote
Old 04-04-2008, 07:17 PM   #3 (permalink)
SRT of the Month
LilSparkPlug's Avatar
Member Number: 17636
Trader Rating: (70)
Sounds like the multifunction switch. Its located in your steering column, its a decent sized plug. Check to see if its melted/burnt at all.
Old 04-05-2008, 05:01 PM   #4 (permalink)
redsrtfour's Avatar
Trader Rating: (13)
thanks for the help my fmic cut my fog light wires got it fix thanks
Page generated in 0.14915 seconds with 13 queries
