**** Due to your overwhelming response & the demand for retrofits, I will not be taking any new orders till after the Christmas Season. I ask that you be patient as we get caught up on the influx of orders we received. Thank you all for your continued support & business. ****
ND4SPD DESIGNS Specializes in SRT / MOPAR Custom Lighting Solutions
Retrofit Services Overview
With each retro there is extensive amounts of time, labor, & care invested to give you the improved lighting performance or jaw dropping looks you desire. Ican create a custom headlight with OEM looks all the way to complete one-off designs.
- ND4SPD DESIGNS HID Kits, Bulbs, Relay Harness's
- Projector Retrofitting, Color Modding, & Clear Lenses
- Painting, Shaving, & Customization of Housings
- CCFL & LED Halo's, Angel Eyes, Demon Eyes,
- LED Turn Signals & Accents
- Color Lens Tinting, Lens Smoking, & Lens Protection
With that being said, there's a reason retro's aren't cheap. I do my best to make them as affordable as possible without sacraficing quality. I'll work with you to plan out something to fit your budget. We can go from simple & functional all the way to full on crazy show custom.
There's two places to start. Determine the headlight you want to use & I'll let you know what projectors will fit. We can also go backwards by starting with the projector you want and from there I'll help you to decide what headlights will be best suited. After that we'll discuss add on's & extra's to tailor a set-up that's sure to fit your needs.
Neon SRT-4 Retrofits
MDX Basic Retro - Starting at $500 (coSRToc Member Pricing = $100 Off)
- New Halo Projector Headlights ( -$200 if sending used headlight)
- Acura MDX Projector Swap
- Custom CnC'd Mounting Brackets (retains the use of the factory aiming adjustments)
Extra's & Upgrades (Additional cost added to the basic price)
$15 - Painted Projector Shield
$50 - Color Match or Custom Color Painted Shroud (inside headlight)
$50 - New OEM Headlight Gaskets
$50 - Reconditioned Headlight Lenses (remove light scratches, yellowing, hazing)
$60 - Clear Cost Headlight Lens Protection. Available in Clear, Smoked, or Tinted Colors (Highly Recommeded)
$35 - Side Led Color Change
$40 - Stock Angel Eyes "Halo" Color Change
$75 - CCFL Angel Eyes "Halo" Upgrade
$100 - LED Angel Eyes "Halo" Upgrade
FX-R Bi-Xenon Basic Retro - Starting at $700 (coSRToc Member Pricing = $100 Off)
- New Stock Style Headlights ( -$200 if sending used headlight)
- Mercedes E55 Projector Swap
- Custom Vacuum Formed Shroud
- Bonus: All FX-R's come already fitted with Retrofit Source's famous Clear Projector Lens Upgrades ($75 value)
$25 - Demon Eye Led's
$75 - Lamin-X Headlight Lens Protection. Available in Clear, Smoked, or Tinted Colors. (Highly Recomended)
$100 - OEM Style Chrome Shroud Upgrade (instead of vacuum formed shroud)
E55 Bi-Xenon Basic Retro - Starting at $750 (coSRToc Member Pricing = $100 Off)
- Custom Bezel/ Shroud
$75 - Retrofit Source's Famous Clear Projector Lens Upgrades (Highly Recomended)
TL Bi-Xenon Basic Retro - Starting at $800 (coSRToc Member Pricing = $100 Off)
- Acura TL Projector Swap
I'm slowly getting pictures together so PM for details if you're not sure what something is or means?
The price to add the extra's like LED's, Painting, etc... is cheaper when doing a retro because I'm already in there to do other stuff. I already have the headlights opened up & I'll have to seal them back anyway. If getting upgrades
without having a projector retro done then you'll obviously need to pay a small labor charge.
Labor (open, install, & re-seal) = $75
LED's, CCFL's, Upgrades
Pricing for JUST the LED or CCFL Ring Upgrades on Ebay/ MPX /Style A Projector Housings.
CCFL Rings $15 each x 4 = $60
Inverters $7.50 each x2 = $15
TOTAL = 150.00 + Shipping
LED's $12.50 each strip x 4 = $50
Rings $25 a pair x 2 = $50
Labor (open, drill 64 holes, install, & re-seal) = $100
TOTAL = 200.00 + Shipping
That might sound a bit expensive at first so I broke it down so you can see that there's no real "fluff" in the price. It's about 3-6 hours of work... really I should be charging triple for labor. If interested you can send me your projectors & I'll mod them & send back. Another option is purchasing directly from Modern Performance & sending them straight to me.
Lighting Products
$115 - HID Upgrade Lighting Kits. 3500K - 8000K Available
$25 - HID Relay Wiring Harness (single xenon)
$35 - HID Relay Wiring Harness (bi-xenon)
$40 - HID Bulb (1 Pair). 3500K - 8000K Available
$ASK - Genuine Phillips D2S 4300K Bulbs (both new or slightly used available)
$70 - Bi-Xenon Projector Mounting Bracket (Bi-Xenon PMB's) 1 pair
$100 - MDX Projector Mounting Bracket (MDX PMB's) 1 pair
$50 - LED Halo Rings (MPX/ Style-A projectors only)
Styling & Dress-Up Products
$40 - CNC'd Aluminum Coil Covers (Raw Finish)
$50 - CNC'd Aluminum Coil Covers (Polished Finish)
Performance Products
$??? - SRT-4/ Neon Coil On Plug Set-up
(coming soon)
Miscellaneous
Please feels free to shop around but remember... ND4SPD DESIGNS prides itself on
customer service &
tech support for anything you purchase through us. I'll guarantee correct fitment on all HID kits & other lighting products for all SRT/ Mopar Vehicles as well as warantees on parts & labor performed. Do you get all that with ebay sellers? Ultimately the choice is yours but I've done all the hard to make it as easy as possible for you!
I'm always working on new projects & trying to fill voids in the market for Aftermarket Lighting, Dress-up Accessories, & Performance Products. Let me know there's something you'd like to see, or if you have any other questions?
