Old 08-02-2006, 08:06 PM   #1 (permalink)
SRTpusher's Avatar
Member Number: 1139
Default My retros are at my house!!!
but i am stuck at work
pics and install coming tonight
SRTpusher is offline   Reply With Quote
Old 08-02-2006, 11:19 PM   #2 (permalink)
SRT4Donkey's Avatar
Member Number: 29887
Trader Rating: (12)
fred, there gonna look sick!!!
SRT4Donkey is offline   Reply With Quote
Old 08-03-2006, 12:28 AM   #3 (permalink)
SRTpusher's Avatar
Member Number: 1139
well... not getting installed tonight... need to ask hak a ?? about the harness.
Old 08-03-2006, 12:46 AM   #4 (permalink)
Member Number: 17276
Trader Rating: (41)
Maybe I can help. I just recently sold my retro and installed them on my buddies car. Lemme know what the problem/question is
SilverSerfer is offline   Reply With Quote
Old 08-03-2006, 12:53 AM   #5 (permalink)
SRTpusher's Avatar
Member Number: 1139
what wire goes where?
i know fused goes to the battery. then where do i ground out the wires on the blub part of the harness? is there a screw in the area already or do i need self tapping screws?
Old 08-03-2006, 12:53 AM   #6 (permalink)
Trader Rating: (41)
PM sent.
Old 08-03-2006, 01:01 AM   #7 (permalink)
Trader Rating: (41)
you got TL projectors right?
Old 08-03-2006, 07:54 AM   #8 (permalink)
haknslash's Avatar
Member Number: 21686
PM replied!
Old 08-03-2006, 08:01 AM   #9 (permalink)
BSoares's Avatar
Member Number: 29711
The answer to where which wire goes to should be posted as more people will need it (including myself :p). I also have no clue where to connect each of the wires. My last car had an HID kit and I saw the guy installing but it had no relay or many wires (it wasn't bi-xenon). So it was pretty simple.
Bruno Soares
Stock 2005 SRT-4
BSoares is offline   Reply With Quote
Old 08-03-2006, 08:41 AM   #10 (permalink)
haknslash's Avatar
I usually PM you all the info or they have PM'd me. The diagrams have been posted on here before in a few threads.
I used to suply this with the harness but my harness ballast leads can differe from time to time. Sometimes its yellow power leads and other times its red. Just depends how much wire of one color I have at the time I make it. Also not mentioned below in the instructions is that there is also a chassis ground coming from each ballast lead. Those have ring terminals on them as well just like the relay ground does.
If you run bi-xenon you'll need to incorporate this, which I do include the diode.
Old 08-03-2006, 12:53 PM   #11 (permalink)
SRTpusher's Avatar
Member Number: 1139
so to ground the ring terminal, i just drill a self tapper into the fender?
Old 08-03-2006, 02:37 PM   #12 (permalink)
haknslash's Avatar
Scrap back some metal first so that you get a good connection
I also like to use "star" washers (spiney sharp edged washers) as they will grip onto the metal and not allow the ring termianl to spin.
Old 08-03-2006, 03:30 PM   #13 (permalink)
SRTpusher's Avatar
Member Number: 1139
W3RD
Old 08-04-2006, 04:30 AM   #14 (permalink)
neonelite10's Avatar
Member Number: 13966
Pictures!!!!!!!!!!!!!!!!!!!
Your sig should not exceed 100KB
edited by peteblksrt4
neonelite10 is offline   Reply With Quote
Old 08-04-2006, 12:22 PM   #15 (permalink)
SRTpusher's Avatar
Member Number: 1139
pics are up Haknslash H7 Retros installed!!!
as with every 1 hr job it took me 2.5
Page generated in 0.18059 seconds with 13 queries
