Old 07-22-2005, 09:38 AM   #1 (permalink)
raven_328's Avatar
Member Number: 21553
Default My drivers side fog KEEPS BURNING OUT!
What should I do? Dont know why its burning out all the time Its burning out every 2 months or so, thats not right.....
Jared
Mopar Stage 2 w/out Toys, MSD Ignition, MSD Coil, MSD Wires, NGK Iridiums, AEM Short Ram CAI, Turbo XS RFL BOV, 20$ Catch Can, Greddy Turbo Timer, Greddy Electronic Boost Controller with Remote Switch, Mopar Short Throw with Boogar Bushings, Underdrive Pulley, Eibach Pro kit, KYB Struts, tower braces, End Links, Hard Up Pipe, 3' catback exhaust with remote opening downpipe, APG DogBones Upper and lower Mounts.
raven_328 is offline   Reply With Quote
Old 07-22-2005, 09:40 AM   #2 (permalink)
Member Number: 7088
Trader Rating: (88)
do u hate the dealership near u?? just take it in. lights have nothing to do with all those mods u have
adrenalineaiax is offline   Reply With Quote
Old 07-22-2005, 09:42 AM   #3 (permalink)
haknslash's Avatar
Member Number: 21686
What kind of bulbs? Stock regular halogens or other? also check for leaks to see if water is making its way in. Sometimes condensation will kill bulb life rather quickly. also are you installing the bulbs without touching them like it warns you about? oils will kill the bulb life VERY quick because it will super heat in that portion where your body oils are on the bulb.
Old 07-22-2005, 09:46 AM   #4 (permalink)
raven_328's Avatar
Yah I know my mods have nothing to do with my lights. And I never touch the new bulb, and the first ones were stock and the rest have been aftermarket. But the reason I dont blame the aftermarket bulbs is because the other fog light has been working fine. I will just take it in........thanks guys
Old 07-22-2005, 10:14 AM   #5 (permalink)
haknslash's Avatar
A word for the wise, if you take it in with the aftermarket bulbs, expect them to automatically put the blame on those before they do anything.
Old 07-22-2005, 10:18 AM   #6 (permalink)
Member Number: 114
I don't know if our foglamps have a drain hole or not, but don't attempt to "modify" the foglamp in any way. This includes if you've tried to "seal" it from moisture. Sometimes they have to have some type of drain to keep them from fogging up and holding in the condensation.
Good luck!
-Sam
-SamelCamel
Samel_Camel is offline   Reply With Quote
Old 07-22-2005, 11:08 AM   #7 (permalink)
Member Number: 7088
Trader Rating: (88)
i didnt know u had aftermarket bulbs.. put ur stock ones back and short one.. the one that keeps burning out and say its burns out a lot so they'll replace ur wiring problem or w/e it is
Old 07-23-2005, 02:55 AM   #8 (permalink)
Member Number: 28230
I've had the same issue, some Neons have had wiring issues like this. Dealership should square you away w/new harness's.
Modrod03 is offline   Reply With Quote
Old 08-09-2005, 08:46 AM   #9 (permalink)
raven_328's Avatar
Ok........
Old 08-12-2005, 05:05 PM   #10 (permalink)
Member Number: 32172
mine's done it too. yours wouldnt happen to be an 03 would it?
SupaDawg is offline   Reply With Quote
Old 08-25-2005, 11:40 PM   #11 (permalink)
Member Number: 24486
my high beam's went kaput a while ago..they just replaced the fuse, and they work fine now...probably not the same issue, but its related in a way.
Orange_Keebler is offline   Reply With Quote
Page generated in 0.17278 seconds with 13 queries
