Does anybody know how to change the halo bulb or what type of bulb it is. Because my passenger side headlight the halo wont come on. Only some times they turn on. I think probably ill have 2 check the wires, but just in case i wanna know what type of bulb it is.
I actually have yellow to replace my stock ones whenever they need to be replaced and I like my blue leds and actually are a kind of super white in my op.
i need to replace one of them that died so were can i find them
call modern they should have them, they sent me my replacements when the halos didn't light on the passenger side. If not see if they have the part number, and check out Autolumination.com they might have them in what ever color you want.
Pssshh! It's just a neon!
1/4 Mile 12.97@106mph
60ft 2.07(street tires)
to change the halo bulb first you have to remove the light completly. then on the bottom of the light there are 2 rubber grommets. 2 wires each(1 white,1 black). use a flat head screwdriver to pop the grommet off. then the led is just pushed into the halo housing. wiggle it out. they are not marked as possitive or negative, so i compared the new one to the old and tried to match it up. and it worked. (if it doesn't reverse wires, if still nothing look into transformer issues)
do you have hid bulbs?
my halos started to go crazy like that after I installed hids
the bulbs are ok, i also have figure that out, it seems like its some kind of interferences from the hids...
no, i have the fake hid bulbs that modern sells the nokya bulbs i think. even then i think your thinking florescent bulbs and i don't think they put those ub cars...they are the only light that i know of that effects electronics
