Old 06-12-2009, 07:58 PM   #1 (permalink)
Member Number: 40223
Trader Rating: (12)
Default MPX halo headlamp leaks
anyone have any issues with the MPX halo's allowing moisture in after rain or going through a car wash?? just my drivers side headlmap seems to be getting moisture in it on rainy days, one day of no rain and cruising up the hwy it dries rite out??
2005 SRT4 stage 2, Tein H springs, AEM WB, Mpx BFMIC , 3" TBE , 3" 02, 55mm TB, N2MB WOT box , PTP fuel re wire, 2.5" Hot/charge pipe, AGP cold pipe, HKS SSQ bov, FMwga, E1turbo , DSP tuned .
95 Z28, Vortech Ttrim, few other mods....
2006stratus2.4 is offline   Reply With Quote
Old 06-12-2009, 08:39 PM   #2 (permalink)
Member Number: 70366
i have had the same problem i used the factory headlight rubbers and it help.
SLOWMO
SlowmoSrt4 is offline   Reply With Quote
Old 06-13-2009, 12:27 AM   #3 (permalink)
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (46)
Alot of them leak from the factory. They don't do a very good job of spreading the sealant evenly or the proper thickness (about 3/8th an inch). This causes then to leak.
See this thread for idea's on how to fix it.
John Ruckman
Stage 3 with all the goodies
See My Ride
ND4SPD DESIGNS
Old 06-13-2009, 08:30 PM   #4 (permalink)
Trader Rating: (12)
well thats what im wandering is it problems with the lens itself not being sealed right or the seals around the turn signal and headlight bulbs usually? i never see any actual water in the lamp, just condensation. also what are all the lil caps along the back of the lamp for? they just pop right off and you can see right inside the lamp, can i just seal all these up or are they there for some type of ventilation or something....?
Old 06-14-2009, 10:16 AM   #5 (permalink)
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (46)
All headlights/ taillights are vented to allow equalization of air temps preventing excessive condensation. Some minnor condensation is normal on all headlights, if it's pretty bad then you probably have a leak as well.
Remove the headlight. Remove all the bulbs. Use a hair dryer to dry our all the extra mounture inside. Re-install the bulbs & make sure they are seated & all gaskets are in place. If you still have condensation issue then you have a leak around the lens. Repeat steps except use silicone sealant around the outside edge. Allow to dry 12-24hours before re-installing & using.
Page generated in 0.15050 seconds with 13 queries
