Old 05-09-2007, 08:04 PM   #1 (permalink)
SilverTurboRidin's Avatar
Member Number: 12985
Default mounting ballast for hid kit?
Hey guys was wondering if you can give me some pointers of where to put the ballast for the HID kit. I have 2 mounting brackets and all just trying to find a place to put em....so yeah PLEASE let me know and if you have pics even better.
-Justin
AGP 50 trim..... Yeah its sexy.
Grrr- 50 trim is on hold....Rebuilt motor done.
JE pistons 8.5:1, crower springs & retainers, eagle rods, ARP studs...But not entirely done ha
SilverTurboRidin is offline   Reply With Quote
Old 05-09-2007, 08:14 PM   #2 (permalink)
goats srt's Avatar
Member Number: 47689
i dont have pic but i mounted mine to the battery tray
Old 05-09-2007, 09:51 PM   #3 (permalink)
SRToc Member
redsoxsrt's Avatar
Member Number: 28768
Trader Rating: (42)
when i did mine i mounted one right to the right of the washer fluid bottle on the frame (so u couldnt see it with the lights back on the car) and i mounted the other one in the same spot on the other side
Old 05-10-2007, 10:40 AM   #4 (permalink)
how hard was it to get too...im pulling out the entire headlight housings in like 5 minutes
Old 05-10-2007, 11:25 AM   #5 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
My drive side is mounted underneath the "shelf/sheetmetal" the driverside headlight sits above. Pasenger side is down by the water bottle. Be sure your connections are waterproofed or you'll develop corrosion down there. Trust me
Old 05-10-2007, 11:34 AM   #6 (permalink)
Yeah they are lol.
Worst thing ever just happened though passenger side headlight.
The two bolts used to secure the light a black bolt...(longer) and a grey one...i snapped the head off the grey bolt....now i cant take out that housing, some im trying to work around it.
Old 05-10-2007, 12:50 PM   #7 (permalink)
haknslash's Avatar
Just undo your bumper bolt up top. Then pull back your bumer right where the turn signal area is. you'll be able to gain access to the bolt itself. Use some pliers and work it out.
Old 05-10-2007, 03:47 PM   #8 (permalink)
i tried....Didnt work to well, but the lights are in and work great. I do hear a slight humming noise for about 2 seconds when they are first ignited...any ideas?
Old 05-10-2007, 04:26 PM   #9 (permalink)
haknslash's Avatar
Its normal. Check to make sure you're not getting any radio interference.
You are on a upgraded harness correct?
Old 05-10-2007, 08:36 PM   #10 (permalink)
viper2pt0's Avatar
Member Number: 30503
Hey hak...im on a dual relay upgraded harness I made. I still get a load of radio interference when I first turn on my lights, always have. Now my passenger light went out....I think my ballast finally shit itself on that side. You don't happen to have any ballasts laying around you're lookin to unload do ya?
Flame Red '05 SRT-4 ACR
Performance: Mopar BOV Conversion, Mopar STS W/ Booger bushings, F & R Strut tower bars, $20 Ebay CC, K&N DIF, GReddy Full Auto TT, DCR Bored TB & Spacer, DCR PnP Intake Manifold, JMB UPP w/ HKS Bov, NGK Iridium Plugs, QuickWhips FMIC.
Non-Performance: 2 10's in Custom Fiberglass Boxes, Homemade Grounding Kit, Glacius PC'ed Valve cover, PC'ed Intake Manifold, pwerks beam.
viper2pt0 is offline   Reply With Quote
Old 05-10-2007, 10:58 PM   #11 (permalink)
haknslash's Avatar
Nah, I don't stock anymore HID stuff. You can buy some on HIDPlanet but they have a oem connector and alot of kits don't have that type of connector. The only time I've heard of people have intereference is with using a kit. I'm not sure if its just the quality of the electrical components/ballasts versus oem grade ballasts but there seems to be a link only with kits.
How do you have your grounds hooked up and how long are they?
Old 05-11-2007, 05:13 AM   #12 (permalink)
viper2pt0's Avatar
yeah I saw the ones on HID planet, I'll probably end up getting a set of those if it does turn out to be that mine is dead. I'll be looking into it this weekend. I have an e55 maxima retro that I made, but Im still using my ballasts from my kit. I'm sure thats the problem. The shielding on them is probably sh*t. how much waterproofing is needed on the bosch ballasts that HIDPlanet sells? oh and each of my ballasts has a dedicated ground that go straight to the negative terminal on the battery.
Old 05-11-2007, 08:28 AM   #13 (permalink)
haknslash's Avatar
HIDP sells only Gen 3 Hella ballasts
Your grounds need to go to the chassis, not the neg. battery terminal. Grounds don't need to be any longer than they need to. Try and stay less than 12".
Old 05-11-2007, 01:29 PM   #14 (permalink)
i have a upgraded harness kit. Im actually thinking about making my own relay setup. Cause i wanna utilize 8gauge wire if it will help any.
Old 05-13-2007, 11:37 PM   #15 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (30)
x2. looks clean that way. that and there isnt much room in the engine bay anyway.
beyondspexj is online now   Reply With Quote
