Anybody having issues with moisture leaking in your black housing headlamps? I really like them and am contemplating a purchase but I don't want to be disappointed with cheap quality headlamps.
Also, hak if you read this, what are your thoughts on silica gel packets inside headlamps for moisture? I saw this on the cobalt forum and it peaked my interest.
Mercury got the packets and idea from us over on hidplanets forums. Lots of companies use those packets in anthing to help fight of moisture in enclosed areas so it could only help. People have had success with them on hidplanet so far. To get your packets go here http://www.hidplanet.com/silica.html
As far as the black housing headlights leaking, this is the first I've heard of. They are not made by DEPO but rather Eagle Eyes so there is a slight drop in quality but overall I haven't seen anyone mention them leaking around here. A good buddy of mine, speedooooo on the forums, hasn't mentioned his leak and he's been having them ever since they came out. Perhaps you got a bad batch maybe. I do know this, on the Eagle Eye headlights, the turn signal bulb and socket they use are CHEAP CHEAP CHEAP!! About 8 out of 10 I come across literally fall slap apart right at the socket and bulb LOL. I can touch one and it will fall apart LOL. Defiantly need to use the sylvania running gear that comes stock and also with the DEPO units.
I got mine off ebay and I havent had any moisture problems whatsover. I just used the rubber piece from the oem headlights in order for them to fit perfect. The rubber piece that came around the aftermarket headlight was very thin and It would leave me with a slight gap between the bumper and headlight.
Yeah I've noticed that issue on the rubber piece as well on the aftermakret lights. However, the DEPOs sit pretty close to what the factory ones did and isn't as cheap of rubber as the Eagle Eyes ones are. The DEPO ones haven't had any gaps on mine but the Eagle Eye ones have been known to cause a small gap here or there. Simple fix is just what you mention, to reuse the stock OEM rubber surround and they'll fit nice and snug again.
Hey Hak,
You mentioned the socket and bulbs are cheap. Is that somthing that can be easily transfered from the original headlight or is it the part of the housing that it screws into? Thanks
Dan
I had the moisture issue in my driver side issue. It was due to the fact that 1) I did not have the socket in completely tight and 2) you HAVE to use the socket connecter that comes with the lights. If you reuse your stocker then you will get moisture.
Thanks for clearing that up. In your opinion do you think they are a quality product? Also Ive noticed that 4-headlights sells a set for 200 + shipping and some other place sells them for 160 + shipping, do you know if theres any diffrence between the two? All Ive heard is there is only one company that makes them so I had been under the assumtion that they were the same. Thanks again.
Dan
I had moisture in the passenger side unit. I took the rubber rings off and replaced them with the stock ones. The ones that came with the black headlights were super thin and already starting to tear.
