Old 05-23-2009, 08:35 PM   #1 (permalink)
Member Number: 40223
Trader Rating: (12)
Default modern performance projector adjustment??
i just picked up a set of the modern image projectors, anyone know how to adjust the beam up and down? the pass side beam aims like 6" higher then the drivers side and i can only seem to adjust it left to right not up and down? the projector has 2 screws under the bulb you can turn with your fingers, high beam has 3 screws 2 above the lamp and one below that have to be adjusted with a flat head. the instructions they give you are a photo copied piece of paper in half japanese and only shows wiring install not aiming adjustments
2006stratus2.4 is offline   Reply With Quote
Old 05-23-2009, 09:28 PM   #2 (permalink)
Trader Rating: (12)
i got it
Old 05-23-2009, 10:23 PM   #3 (permalink)
AngrySrt's Avatar
Member Number: 71255
lets see pics how the look
2003 srt-4 stage 1 pcm, DSP tuned by john at ptp, stage 2 injectors, agp wastegate with ptp spring mod,agp full race bfmic, agp intake, areoforce scan guage, mpx extrude honed mani,mpx 62 mm throttle body, cti charge pipe,agp up pipe with hks bov, aem wideband, 3 inch side exit, hold 17.
Jon at PTP is the shiznit!!!!!
AngrySrt is online now   Reply With Quote
Old 05-23-2009, 10:53 PM   #4 (permalink)
Trader Rating: (12)
i dont have any nite pics, sucky thing is the whole lamp needs to come out to adjust the beam and i had to use my stock rubber seal to to get a good fit with no gaps, other then that they seem pretty good .
Old 05-24-2009, 08:41 PM   #5 (permalink)
gatekeeper's Avatar
Member Number: 13391
Those actually look better on the car, than I thought they would....looking at the c/u's on modern's webs.
2004 E-Blue SRT-4
2008 U-Silver Cobalt SS/TC
gatekeeper is offline   Reply With Quote
Old 05-24-2009, 08:55 PM   #6 (permalink)
OrangeBlastSRT's Avatar
Member Number: 41476
Trader Rating: (27)
i was thinking about picking up a set of these. how do you like them? any difference over the beam at night over the stock? alot more light or about the same?
OrangeBlastSRT is online now   Reply With Quote
Old 05-24-2009, 09:45 PM   #7 (permalink)
Member Number: 22460
i got it
Can you explain how?
I'm trying to adjust mine, I think the outer bolt (near the fender side) does the up and down, but want to be sure
When I installed them, they were pointing to the ground, now they are way too up; but once finished, I'm sure they will be great
I really like mine (got them on ebay) with HID they perform better than stock with HID, Of course a retro would be better, but they are good, for the price, etc
And I was afraid I wouldn't like the halos (ricer, etc) but they look great!
AudioFan is offline   Reply With Quote
Old 05-24-2009, 09:51 PM   #8 (permalink)
Trader Rating: (27)
is it hard to hook up the halos or are they hard wired in already?
Old 05-24-2009, 10:48 PM   #9 (permalink)
Trader Rating: (12)
i believe the outer screw under the projector tilts it up and down, inner one left/right. as for the light output its better IMO over stock, nothing to brag about but noticeable. the halo rings really look good at nite when lit, you cant really see them in the day time tho, so there not as bright as say a bmw that can be seen in the day but there def bright enough at nite. as for wiring there is 2 ground and 2 power wires for each lamp,( 1 for the halo's and 1 for the LED's) I just spliced them into the park lamps, fairly easy.
Old 06-15-2009, 11:34 PM   #10 (permalink)
Member Number: 72124
Thumbs up
im getting ready to write up a sticky how to swap out the bulbs on the rings so the rings are alot brighter. as for the issue with getting them alligned right, it sucks but i spent an hour and a half and i cant remember which was which so i just twisted and turned untill it was dead center. i feel your pain but fyi a 6000k HID kit looks great on them, no hot spots. i just need to find out how eyelids look on them befor i go sticking them on mine.
torres806 is offline   Reply With Quote
Old 06-16-2009, 11:56 AM   #11 (permalink)
SRASRT4's Avatar
Member Number: 46928
they are a pain to adjust...eyelids look great on them...
SRASRT4 is offline   Reply With Quote
Old 06-16-2009, 01:13 PM   #12 (permalink)
Turbolife06's Avatar
Member Number: 62311
they are a bit of a pain to adjust but they are sick lights, i just did the wire swap so now my halos and my fogs are on and its sweeet. but as orange blast asked the halos arent hard to wire you can wire them a few ways for when they turn on but its all in the insturctions just cut wires and solder or tape whatever your pref is.
TIME TO GO FOR SOME POWER!
Turbolife06 is offline   Reply With Quote
Old 06-21-2009, 04:51 PM   #13 (permalink)
Pomz23's Avatar
Member Number: 64878
Trader Rating: (19)
I just bought those. The instructions are absolutly worthless. half english and half chinese. lol and nothing usefull. it says how to hook up the negitive wire, but nothing about the positive lol. Got them off ebay though. after a day the damn passenger side projector bulb went out.
Metal Werkz - For Sale: New Custom Aluminum Door Sills and Radiator Shrouds!!!!!! Click here for my site.
Pomz23 is offline   Reply With Quote
Page generated in 0.18588 seconds with 13 queries
