Old 04-28-2008, 06:33 PM   #1 (permalink)
AntsSilverBullet's Avatar
Member Number: 27289
Default Modern Performance Halo Headlight Prob!!
Put mine in and the Projector on the drivers side doesn't light up when I turn my headlights on, instead the bulb next to it that acts as your brights turns on..... and when I turn my brights on the projector turns on, how do I fix this or do I have a faulty Headlight?
2005 Silver Dodge SRT-4
Mopar Cold Air Intake | Mopar Short Throw Shifter | Clear Bumper Lens | Mopar Catback Exhaust | D.C Sports Front/Rear Strut Bars | Black LED Tail Lights | Mopar Stage 2 w/o Toys | AGP UHP w/Greddy Type S BOV | Eibach Pro Kit Springs
AntsSilverBullet is offline   Reply With Quote
Old 04-29-2008, 07:02 AM   #2 (permalink)
Bump for some advice!!
Old 04-29-2008, 09:09 PM   #3 (permalink)
SRToc Member
kaminarineon's Avatar
Member Number: 11151
Trader Rating: (12)
did you hook up the wires correctly?
dude the only way ull beat a Stage 3 SRT is if u shoot the driver
post 38:
http://forums.bimmerforums.com/forum...ht=srt4&page=2
kaminarineon is offline   Reply With Quote
Old 04-30-2008, 01:34 AM   #4 (permalink)
Member Number: 12902
sounds like you have your brights wired into your "regular" wires and vice versa... jus disconnect them and swap and see if that solves your problem.
PoloBoy12 is offline   Reply With Quote
Old 05-03-2008, 07:37 PM   #5 (permalink)
They come as one connection already pre wired.... That's why I was thinking they may be faulty!
Old 05-03-2008, 07:42 PM   #6 (permalink)
csealy.31's Avatar
Member Number: 28688
Mine did the same thing. The wires that power the lights were backwards from the factory. I just switched the wires around. One other thing to be careful of.. mine fog up in the rain. I have had two sets and both do the same thing. They are not sealed up very well. Also, make sure you use your existing rubber gaskets otherwise you'll get rain all over the driver's side of your engine bay (it leaks straight down onto the CAI filter)
Lots o' stuff, but still not enough
csealy.31 is offline   Reply With Quote
Old 05-04-2008, 10:30 AM   #7 (permalink)
Alright good, so it's not just mine. Thanks a lot man I will do that. As for the gaskets, I did that already cause there was a gap with the ones that came on them, I never knew it could get as serious as dripping down into the CAI though. Thanks a lot dude, I appreciate it!
Page generated in 0.20882 seconds with 11 queries
