Old 10-30-2009, 09:30 PM   #1 (permalink)
Srt billion's Avatar
Member Number: 72982
Default Major Lighting issues
Big Time lighting issues need advice.
The cars high beams work 100%
The low beams work about half the time
Rear lights do not work at all
Brake lights work 100%
and parking lights dont work at all.
The fuses blow for all of these so i replace them and when i do they just blow out. The keyless entry doesnt work either. Ive check what i can for wires and nothing is cut, burnt or anything.
Srt billion is offline   Reply With Quote
Old 10-30-2009, 11:15 PM   #2 (permalink)
o5RedSrt-4's Avatar
Member Number: 71354
did you check your grounds? How do the bulbs look?
o5RedSrt-4 is offline   Reply With Quote
Old 10-30-2009, 11:59 PM   #3 (permalink)
Member Number: 30934
I have a similar problem but it's my dash/parking light fuse blows only when I accelerate, check everything i can possibly check unplugged everything but find when i put in a 25 amp fuse have no problems. Your remote keyless is on a different fuse but is tied into your parking lights and has a separate power source that also operates your parking lights i have been all through this wiring harness. The wire your needing to trace is the pink with red stripe and the black with yellow stripe. Good luck hope hope you can get your figured out.
Gringo3825 is offline   Reply With Quote
Old 10-31-2009, 08:39 AM   #4 (permalink)
SRT of the Month
LilSparkPlug's Avatar
Member Number: 17636
Trader Rating: (70)
Did you check your multifunction switch and it's wiring/harness connector?
LilSparkPlug is online now   Reply With Quote
Old 10-31-2009, 09:12 AM   #5 (permalink)
I pulled the wires out of the multifuntion switch and put a fuse between the two wires pulled out the gauge cluster and pulled the remote keyless relay box out. Yes your car will start without all that couldn't believe it but your parking lights won't work at all if you pull your remote keyless relay box. both fuses popped when i put 15 amp fuses in when I put 20's in only the one in the fuse box would pop. when i put 25's I have no problem. The major problem is that the wire suppling all those light's is way to small. Try running a temporary power from your battery and pull the black w/yellow stripe out of your multi connector and put a fuse between it and see if it still pops if i does the problem is in your harness if it does not your problem is between the switch and fuse box.
Old 11-01-2009, 10:33 PM   #6 (permalink)
TheRedDeath04's Avatar
Member Number: 71307
not that it may have anything to do with it or not but the wires behind the clutch on my car were frayed and i keept having fuses blown but that was long ago and i dont rem what was blowing lol but it took me awhile to find that out. the plastic protector behind my clutch pedal was gone and the wires were just hanging so i tried to secure them up higher and never have had the problem again.
TheRedDeath04 is offline   Reply With Quote
Old 11-03-2009, 09:23 PM   #7 (permalink)
Thnxx guys, im getting into it tomorrow and ill post up and keep it updated.
I just installed a apexi neo and it works fine but the lights dont work now. Maybe that could have been a problem? Idk ill check everything and let you guys know
Old 11-04-2009, 07:18 PM   #8 (permalink)
SRT of the Month
Trader Rating: (70)
If all of those lights aren't functioning I would definitely look into the MFS....it's the control center for them.
Page generated in 0.12154 seconds with 13 queries
