Old 12-25-2005, 09:46 AM   #1 (permalink)
Wheat_Burner's Avatar
Member Number: 12004
Trader Rating: (115)
Default Lots of projector questions.
I've decided to start putting the parts together for a projector retro. I'm going to eventually go with the TSX w/ Hak color mod.
I have read quite a bit, but not all of the info on here so please take it easy if these have been answered already:
- If I used the chrome DEPO housings, could I just use a chrome bezel to make the install look cleaner? If so, which one?
- Do I need to use a shroud with a reflector housing?
- If I get TSX projectors, do I also need to use TSX ballasts? (I have a friend at an Audi dealer that might be able to help with some parts.)
- Most of the projectors I see for sale are held together with zip ties. Is that common?
- Do "matching numbers" on projectors make a difference?
- Are there any specific things (other than scratched lenses) to look out for when buying used projectors?
Thanks for any help. I have a feeling more questions will come up.
Quote: Originally Posted by red_power
dale, for someone who sucks at driving like you you sure do talk alot of shit..noob
Wheat_Burner is offline   Reply With Quote
Old 12-25-2005, 09:42 PM   #2 (permalink)
Member Number: 2005
Trader Rating: (24)
I have a question too.
In retgards to the sheets of ABS. What thickness should be used and is there a recommended place to get them?
Greg 04-SRT4
Greg_04-SRT4 is offline   Reply With Quote
Old 12-26-2005, 11:01 AM   #3 (permalink)
haknslash's Avatar
Member Number: 21686
E46 "Xenon" shrouds fit the TSX nicely.
Yes and no. Depending on how you mount the projector, you will need a shroud. If you mount it from the front that is the method I prefer and suggest when using the stock reflector as a base. If you do, you will have exposed bolts and the entire projector body so you would need to use a shroud. Depending on width and size of the projector determins if you can use the stock reflector. If you mount the projector from the back and basically use the stock reflector as a "shroud" then you will need mnore than likely need to incorporate your own adjusters and also hack up the rear of your housing.
You just need a OEM ballast. It doesn't have to match at all.
Yes this is absolutely normal on TSX's that are out of their respective housing for shipping. The TSX is held together on its bracket inside the TSX headlamp by those four areas where your seeing the zip ties. Once you begin to use the TSX's, you will of course not use the zip ties and you will replace them with bolts obviously. So think of the zip ties as a safety for shipment
Sometimes yes and sometimes no . Sorry answer I know but its the truth. I have seen some cases where two projectors had matching numbers but different results. A rule of thumb we go by on hidplanet is no two projectors are ever alike and thats the truth.
Reflector bowl clarity and quality plays a big role in performance. Not a bad idea to ask for pics of the reflector body and shield to ensure everything looks a-ok.
Old 12-26-2005, 11:06 AM   #4 (permalink)
hozay09's Avatar
Member Number: 12622
Trader Rating: (76)
Maybe your looking for something like this Tom? This is what I would want. Don't remember if Hak said it was worthwhile or not.
hozay09 is offline   Reply With Quote
Old 12-26-2005, 11:07 AM   #5 (permalink)
Member Number: 2005
Trader Rating: (24)
Hey Hak
What about the thickness of the ABS
Is the 1/8" thickness okay?
Also, what is the status of the how to, is that going to be updated/finished soon?
Old 12-26-2005, 11:09 AM   #6 (permalink)
hozay09's Avatar
Trader Rating: (76)
Another shot..
Old 12-26-2005, 03:25 PM   #7 (permalink)
MUCH appreciated, Hak.
Hozay - PM sent.
Old 12-26-2005, 03:30 PM   #8 (permalink)
haknslash's Avatar
Quote: Originally Posted by Greg_04-SRT4
Hey Hak
Sorry, didn't see your post earlier heh. 1/8" is what I use.
As hozays picture shows. That guy has mounted them from the front (like I prefer) and is using what appears to be PVC pipe coupler in addition to a chrome bezel. This can be done, but remember, its all on the projector size that determines if you can do something like that.
I also would like to announce that I have just now completed another first. I was abler to modify the stock mounts and was able to use a TL along with the stock adjuster!! So happy! /Rant
Old 12-26-2005, 05:26 PM   #9 (permalink)
wannasupra's Avatar
Member Number: 32741
and that means what?
A new lease on life...
Old 12-26-2005, 07:17 PM   #10 (permalink)
Remax Realtor's Avatar
Member Number: 3827
Trader Rating: (53)
it means he can adjust the beam of his retros with the stock beam adjuster. hak will all of your retros utilize this?
2003 srt-4 *totaled*
2001 neon r/t with srt swap *sold*
2009 dodge caliber srt-4
Old 12-26-2005, 07:23 PM   #11 (permalink)
wannasupra's Avatar
oh, duh. ok i get what he means now. that's tight. so he won't have to bake the housing and take it apart to adjust how high the beam hits. that's really cool.
Old 12-26-2005, 07:35 PM   #12 (permalink)
haknslash's Avatar
Not sure if all will. I'm sure I could get it to that though with enough time.
I never had it to where people would have to bake the housings to adjust the beam. That would be stupid to do LOL. My retyros have always been/always will be adjustable. Its just that prior to now, I used to use 4 bolts to adjust the beam. This time I made some modifications which allows me to use the stock bottom adjuster arm on the housing to move the beam. Before it would require you to remove the driverside headlight to adjust it. Now with this one, he still uses it like stock.
Old 12-26-2005, 07:53 PM   #13 (permalink)
Member Number: 2005
Trader Rating: (24)
Thanks Hak
Old 08-08-2006, 06:27 PM   #14 (permalink)
msrt4's Avatar
Member Number: 40785
Hey Hak
hey everyone where can i buy some of that abs
msrt4 is offline   Reply With Quote
Old 08-08-2006, 06:31 PM   #15 (permalink)
haknslash's Avatar
ABS can be bought online, from a local car stereo shop, etc.
I wouldn't get less than 1/8". Its usualkly sold in 12x12 sheets.
Page generated in 0.26328 seconds with 13 queries
