Old 04-22-2004, 02:08 AM   #1 (permalink)
crayzeeSRT4's Avatar
Member Number: 2553
Default lighting wattage
What is our stock lighting wattage?
is 55/80w = 110/160 too much?
crayzeeSRT4 is offline   Reply With Quote
Old 04-22-2004, 04:15 PM   #2 (permalink)
noblebc's Avatar
Member Number: 5011
Anything higher than the standard wattage is too much. A standard wattage is about 55 / 65. There are many potential problems with going to a higher wattage. You could overload the electrical system, melt the wiring, melt the assembly or most importantly have an illegal beam pattern that is unsafe to other drivers.
noblebc is offline   Reply With Quote
Old 04-22-2004, 04:17 PM   #3 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Yes the stock system is at around 80% already.
If you elect to crank up the wattage, you will need to upgrade your lighting harness.
James
READ AND LEARN:
Old 04-23-2004, 03:51 AM   #4 (permalink)
Member Number: 2553
As long as the bulb draws 55 / 65, it will be safe?
Dose the output wattage matter too?
Old 04-24-2004, 03:33 PM   #5 (permalink)
SRToc Member
nader's Avatar
Member Number: 4801
wattage is basically heat. As long as you run within the factory wattage range you should have no adverse affects on wiring or headlight housings.
Infamous Baywatch quote "Hey Summer, if I hotwire my van can I park it at your moms trailer tonight?"
nader is offline   Reply With Quote
Page generated in 0.21213 seconds with 13 queries
