well for the defroster you have to solder a resistor inline with it...if you dont know how to solder i wouldnt attempt it...but if you do know how its a 5mm blue led i got one with a 30% angle or whatever its called...and i used a 1K ohm resistor but i think you can get away with less i just wanted to be safe so the bulb wouldnt blow...take the switch out take it apart...youll see where the stock bulb was remove it from the base...i had to trim the base shorter so the new bulb would fit with the resistor, then put the led in just like the stock one was in the base...put the base back on reassemble everything and your done the hvac how to is in the gb thread
