Old 06-20-2007, 03:50 PM   #1 (permalink)
Member Number: 33073
Default Led scanner or Alarm indicator on stock alarm?
Iis there any how to on an alarm indicator or led scanner? I have one of those old batman looking led scanners and was wandering if it could be hooked up to a stock alarm and how. I prob just need a power wire that comes on once the alarm is activated. Any help?
All parts should go together without forcing. You must remember that the parts you are reassembling were disassembled by you. Therefore, if you can't get them together again, there must be a reason. By all means, do not use a hammer. (1925 IBM Maintenence Manual)
FloridaBoy07 is offline   Reply With Quote
Old 06-20-2007, 04:41 PM   #2 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
Your car with stock keyless/security system should show its alarm activated. Unless of course you're wanting something that doesn't emit just at the cluster but say on the a-pillar or upper dash top?
If that's the case, you'd need to tap into the signal that feeds the stock security indicator LED in the cluster.
Old 06-20-2007, 04:41 PM   #3 (permalink)
wannasupra's Avatar
Member Number: 32741
there's a little red light inside the gauge cluster that blinks when the factory alarm is armed. perhaps you can use that power wire.
Old 06-20-2007, 04:48 PM   #4 (permalink)
haknslash's Avatar
we must of posted the same time
Old 06-20-2007, 04:53 PM   #5 (permalink)
tinctorus's Avatar
Member Number: 30504
Trader Rating: (43)
no on those scanners from what i remember there was more than just powere and ground there was 5 or 6 wires and a few different ways to wire it up and i believe on eof the way was that i twould turn on when the ignition was turned off
Quote: Originally Posted by FUELED70 View Post
well if she's a tranny, she's the mona lisa of trannies....
tinctorus is offline   Reply With Quote
Old 06-20-2007, 05:00 PM   #6 (permalink)
i have a red, black, and yellow
Old 06-20-2007, 06:06 PM   #7 (permalink)
any way i can do this easy you think?
Old 06-20-2007, 06:22 PM   #8 (permalink)
haknslash's Avatar
Nah, most are 3 wire hook-up.
Floridaboy, I'd be willing to bet you wire it up like most 3 wire scanners with that color code....
Red = 12v
yellow = switched input (alarm armed signal or ignition if you want to use it without a alarm)
black = ground
As for wiring it up, I've already mentioned how you'd do it......
Old 06-20-2007, 07:17 PM   #9 (permalink)
awesome ill try that out thanxs man, Let you guys know how it was maybe do a write up or something. if anyone cares lol
Old 06-21-2007, 09:02 AM   #10 (permalink)
wannasupra's Avatar
just hook that little red light to a relay for a set of underbody neons.
Old 06-21-2007, 10:48 AM   #11 (permalink)
jmduke3's Avatar
Member Number: 11611
I guess I will ask the question of the day then. Anyone know the wire that powers our little red dot?
Gone but not Forgotten Steve a.k.a. Nightshade
jmduke3 is offline   Reply With Quote
Old 06-21-2007, 08:12 PM   #12 (permalink)
Old 06-22-2007, 08:43 AM   #13 (permalink)
wannasupra's Avatar
if you eat beef, you're not supposed to have a dot.
Old 06-22-2007, 09:11 AM   #14 (permalink)
SRToc Member
Member Number: 11820
LMFAO!!!
[live]Mopar Madness[/live]
Eyeless0486 is offline   Reply With Quote
Old 06-22-2007, 07:40 PM   #15 (permalink)
What does that mean?
Page generated in 0.21410 seconds with 13 queries
Search Engine Optimization by vBSEO 3.
