Old 02-11-2007, 11:22 AM   #1 (permalink)
Corners's Avatar
Member Number: 37239
Default LED Replacement for Rear View Mirror Reading Lights?
I want to replace all the interior lights with LED's. I've found the dome and truck lights, but I cannot find the little reading lights in the rear view mirror. They aren't even listed on www.sylvania.com. Does anyone know which bulbs these are, and/or know a good LED replacement?
"Go that way, really fast. If something gets in your way, turn." - Charles De Mar.
Corners is offline   Reply With Quote
Old 02-11-2007, 11:42 AM   #2 (permalink)
Scammer
Member Number: 2261
go to here...
http://www.superbrightleds.com/mini-wedge.html
Get the WLED-WHP LED Wedge Base Bulbs. They are the High Power ones...
These are the ones I use, and the output on them is great. The only other ones I'd get are the WLED-x6 LED Wedge Base Bulbs. Those are almost as good as the high power ones. You will only need two.
I use these High Power 194 white LED's in nearly every accessory lighting on my car that uses a 194 socket accept the LP light which I use the SRT-4Store LED board instead. These 194 LEDs work very good as side marker LED's as well.
FYX193 is offline   Reply With Quote
Old 02-11-2007, 03:15 PM   #3 (permalink)
Corners's Avatar
Quote: Originally Posted by FYX193
go to here...
Thanks!
Old 02-11-2007, 08:52 PM   #4 (permalink)
Member Number: 49928
they have them for the front turnsignals also
redboost is offline   Reply With Quote
Old 02-18-2007, 07:22 PM   #5 (permalink)
Corners's Avatar
I wound up with the WLED-6 bulds in white (color is blue-ish white) for the map lights, and a blue 44mm festoon for the dome light, all from www.superbrightleds.com. Looks good, cost ~$11, and took 5 mins to put in.
Dome light only:
Dome and map lights on:
Page generated in 0.14700 seconds with 13 queries
