Old 09-19-2009, 06:56 PM   #1 (permalink)
Member Number: 64474
Default LED Problems
I have the DEPO LED tail lights and on the last row, 4 of the LED'S went out. Are the LED'S replaceable? I looked at the lights but I don't know?
lipton1 is offline   Reply With Quote
Old 09-19-2009, 07:18 PM   #2 (permalink)
The First Ghost's Avatar
Member Number: 47649
i have a good left side cause my right side went bad. no you cant replace leds'.
The First Ghost is offline   Reply With Quote
Old 09-21-2009, 04:24 AM   #3 (permalink)
Legoman's Avatar
Member Number: 53967
You COULD. But it is hard
You can maybe open the taillight after heating it in the oven.
You can remove the LEDs.
BUT: You will never find out wich led type is installed.
So you cannot guarantee that the replaced LEDs will have the same light output.
But maybe there is just a broken wire / soldering point.
Give it to someone who has the skills to do that and maybe it will work...
Legoman is offline   Reply With Quote
Old 09-26-2009, 10:16 AM   #4 (permalink)
wiggyx's Avatar
Member Number: 58107
Trader Rating: (53)
If an entire row went out then it's most likely not the LED's themselves, but more than likely a resistor or a small solder point failing.
Old 10-09-2009, 12:55 AM   #5 (permalink)
No it's not an entire row, just 4 out of the 6 on the last row on the left
Old 10-09-2009, 01:09 PM   #6 (permalink)
Pureadrenalin9019's Avatar
Member Number: 44393
You will need to unsolder and re-solder the burned out ones. It's a bitch, otehrwise talk to haknslash over at hidplanet.com I think he did a set that were red/yellow bi-color.
Unfortunately, you'll never get a world-class meal when you start with Spam, and neither will you get a world-class hot hatch when you start with a Caliber.
Pureadrenalin9019 is offline   Reply With Quote
Old 10-10-2009, 11:49 AM   #7 (permalink)
Legoman's Avatar
to find the burned one is easy. 4 leds could sit in a row - so if 1 is burned the whole row will stay dark.
so open the taillight, till you can see the led-contacts (the little pins on the undersite of the led-board). connect the taillight to 12v that it lights up.
and now comes the test:
take a little wire with that you can connect the 2 little pins of the dark leds. 1 by 1!
if you connect the pins and the other 3 light up - you found the burned one.
if this test fails with all 4 - the failure siths somewhere else.
test with a multimeter if the leds get energy or where the break is.
Page generated in 0.14873 seconds with 13 queries
