Old 11-07-2009, 01:39 AM   #1 (permalink)
TheRedDeath04's Avatar
Member Number: 71307
Default L.E.D. Dome Light
ok so i bought a led dome light from superbrightleds.com the rigid loop in natural white and i put it in and it works great but when i shut my car off and shut the door and lock it the light dims out like normal but doesnt shut completely off its like very dim but still on i highly doubt that my battery will die out cause of 6 leds at their lowest level but i cant figure out why they dont shut off all the way and when i put my filament back in it stays off maybe because it doesnt have enough juice but idk. just wondering if this is supposed to happen or if my cars dimming switch is broken but i have no clue how to check that.
TheRedDeath04 is offline   Reply With Quote
Old 11-07-2009, 01:45 AM   #2 (permalink)
Zero_psi's Avatar
Member Number: 71591
theres been a million threads on this
ur shit outta luck u have to deal with that or put some resistors in line because there is always a electric current flowing threw that and the leds take less to light up thus why its dim
stage 1 with some other goodies
Zero_psi is offline   Reply With Quote
Old 11-07-2009, 03:46 AM   #3 (permalink)
SRT of the Month
bitts's Avatar
Member Number: 29842
Trader Rating: (98)
put a manual on/off switch.
bitts is offline   Reply With Quote
Old 11-07-2009, 01:10 PM   #4 (permalink)
what if i just disconnect the auto dim and just leave the manual switch connected. i can solder in a resistor but what size and what type should i put i have a set of the projector foglights and those have little resistors on them should i try splicing in one of those or both?
Old 11-07-2009, 01:11 PM   #5 (permalink)
bump.
Old 11-10-2009, 10:18 AM   #6 (permalink)
Legoman's Avatar
Member Number: 53967
no way - the domelight is controlled by a "computer" in the speedo.
so just leave it like it is. it will neither hurt you nor your car.
Legoman is offline   Reply With Quote
Old 11-10-2009, 06:07 PM   #7 (permalink)
but it annoys the shizat outa me at night i can see the light in my rear view mirror and its enough to ambiently light my car but idk in pitchblack you could lookinto my car almost and see whats on the floor is how bright it is in its turned off mode and i dont think its hurting my battery but my apexi turbo timer is at 11v when i start my car and jumps to 13.2 so i think its fine
Old 11-10-2009, 06:22 PM   #8 (permalink)
Legoman's Avatar
remove the led...
Old 11-10-2009, 06:36 PM   #9 (permalink)
Member Number: 71225
consider it a night light when the car is off its fine!
wont hurt anything
ive been using an led dome light for over a year now and it does the same thing
AnsareStg0 is offline   Reply With Quote
Old 11-11-2009, 11:44 AM   #10 (permalink)
so a resistor inline with the positive wont help it at all? or will that hurt something else?
Page generated in 0.14168 seconds with 13 queries
