Old 02-12-2004, 11:24 AM   #1 (permalink)
DaZone's Avatar
Member Number: 1799
Default Just got these turn signals in the mail
Hope the picture attachment shows.. Also, From autolumination. 12LED clear look. amber flashing. let me say, it flashes quick ..
Mods: S3w/toybox,CTI turboback,Iceman TB,AGP CAI,CCA Fmic, Mopar wires w/NGK Plugs. Turbonetics w/greddy type s bov. also: B&G Lowering Springs, Front&Rear Strut tower bar, Rex motor mount inserts, Progress Rear sway bar. AGP S3 Wg.
18" Exel Chromes w/toyo proxes 4
17" Nexo PX-5 w/ toyo proxes 4
Dynoed with HOM : 358hp and 359tq
DaZone is offline   Reply With Quote
Old 02-12-2004, 12:07 PM   #2 (permalink)
ripcuda's Avatar
Member Number: 325
What you have is hyper flashers!
The resistance on LED bulbs is less than incandescant (sp?) bulbs so the turn signal circuit thinks that your front bulbs are burnt out and the hyper fast blinking is the result. The fast blinking is supposed to let the driver know a bulb is out.
The same thing happened on my WRX when I put in LED turn signal bulbs. To get the turn signals back to normal blinking speed, you can easily wire in resistors (from Radio Shack) to the turn signal circuit.
Check out this diagram I made/posted on ClubWRX:
http://www.clubwrx.net/forums/showth...er+turn+signal
ripcuda
'04 Dodge SRT-4 (Stg1, K&N, Dynomax muffler, Perrin STS, Factory cruise control)
'01 Nissan Xterra
'91 Jeep Wrangler
ripcuda is offline   Reply With Quote
Old 02-12-2004, 01:19 PM   #3 (permalink)
SRToc Member
mysrt4ownsyou's Avatar
Member Number: 947
Trader Rating: (51)
i have 14 clear LED turnsignals only that light up red in mine, the 3157's....they blink as normal paced as the stockers, no problem here
mysrt4ownsyou is offline   Reply With Quote
Old 02-12-2004, 11:33 PM   #4 (permalink)
DaZone's Avatar
Member Number: 1799
I like the clear look.
Old 02-13-2004, 12:10 AM   #5 (permalink)
Pitch Black SRT's Avatar
Member Number: 1590
JayMZX has a fix for the "fast flashing" bulbs.
give him a PM
Pitch Black SRT is offline   Reply With Quote
Old 02-13-2004, 12:11 AM   #6 (permalink)
SRTforums Admin
castrol's Avatar
Member Number: 1102
Trader Rating: (35)
I didn't like that they didn't really reflect. They weren't very bright unless
you were at the exact right angle. I took mine out.
~castrol
AIM: castrolsi
Come on, does your signature really NEED
to be any bigger than this? If you have a
premium membership, you can attach all
the photos you want in your posts...
castrol is offline   Reply With Quote
Old 02-13-2004, 12:15 AM   #7 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Be careful when choosing the resistors. In the example in the link, you use two 10ohm resistors in parallel. This effectively is 5ohms of resistance. At 5ohms, and 12 volts, there is 2.4 amps of current going through the resistor. This is causing the resistors to dissapate 28.8W of power as heat. Unfortunately, the two 10W resistors only have a combined rating of 20W. The only downside is that the resistors will get VERY hot, so don't zip-tie them to the wiring harness or anywhere else, or they may cause a fire or melt your wiring.
In the buy/sell forum, I'm selling some 25W, 6.8ohm resistors. I originally purchased the lot to make and sell the equalizers on the forums, but the demand just isn't that high. I'm selling them for basically $2 each but it's the shipping that costs. 6.8ohms will dissapate about 21W of heat. While these resistors are ceramic, cement filled and self-extinguishing (if they caught fire) they still do get quite warm. I run them on my SRT and they become too hot to touch after the blinker is on for more than 2 mins. I just limit my use of the blinkers. I don't sit at red lights with the blinkers on. Ideally the 50W metal encased resistors would be best, but they can get quite spendy.
If you or anyone is interested in the resistors, PM me. More info is here:
http://www.srtforums.com/forums/showthread.php?t=36855
James
READ AND LEARN:
Old 02-13-2004, 12:18 AM   #8 (permalink)
DaZone's Avatar
Member Number: 1799
Im not complaining that they blink fast.. Kind of neat that they do but thanks for the nfo on the resistors.
Old 02-13-2004, 12:23 AM   #9 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Yea the LEDs are neat. I got the 20-LED ones and they're pretty cool. I'm replacing them with Silverstar turns in a few minutes. The sun washes them out too much and you really can't see them from the side all that well. Considering our side markers don't blink (like 1st gen Neons did) it's pretty much a safety hazard. Bulbs look 'bigger' when lit, so I'm goin back to incandescent.
Old 02-13-2004, 12:26 AM   #10 (permalink)
DaZone's Avatar
Member Number: 1799
Your right! good only temporary. waiting on some silverstars to be in stock...
Old 02-13-2004, 01:00 AM   #11 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
(not to hijack) but I just installed the SilverStar turns and holy mother of god they are bright!
I'd like to have turns so bright they're like Chevy running lights (like corvettes). I may need to do a wire mod and see what happens..
Old 02-13-2004, 01:09 AM   #12 (permalink)
DaZone's Avatar
Member Number: 1799
Cool!!!! cant wait to get a set of those with some new foglights.. all out of stock
Old 02-13-2004, 03:43 PM   #13 (permalink)
ripcuda's Avatar
Member Number: 325
jaymzx... thanks for the heads-up regarding the resistors. Learn something new everyday. I hope my old WRX out there in used-car-land doesn't have any issues!
I too agree that incandescent bulbs are brighter than the LED ones.
Page generated in 0.21821 seconds with 13 queries
