Old 08-14-2006, 09:50 AM   #1 (permalink)
Member Number: 44352
Default Interior Neon Light Wiring help...
We have two red neon tubes that we want to splice into her 05 SRT-4. Can someone give us an idea of where to splice into if we want to install them both to light the floor boards (passenger and driver, mounted in the foot wells)? I want to install a toggle switch as well to turn them on at will instead of when the headlights are on. Any help would be much appreciated!
Her: (Current) 05 SRT-4 in Flame Red.
(past) 04 Ralliart 5mt in Pearl White
Him: (Current) 03 Evo 8 in Red
(past) 04 Black 350Z all blacked out with lotsa mods (still didn't handle as well as the Evo)
Raksha333 is offline   Reply With Quote
Old 08-14-2006, 02:04 PM   #2 (permalink)
DannySRT405's Avatar
Member Number: 29955
Trader Rating: (12)
NY SRT CREW
old- stock turbo- 282/344 untuned
new- AGP 60-1- numbers soon to come
DannySRT405 is offline   Reply With Quote
Old 08-14-2006, 06:20 PM   #3 (permalink)
WPGSRT's Avatar
Member Number: 29370
Trader Rating: (35)
I spliced mine into the power atenna wire off of my aftermarket deck cuz it isnt used n e ways are you using some sort of toggle switch? I can post a pick of my setup after it looks really good. I thought it would be rice at first but i was wrong. I got two red 12" tubes uder the dash and 2 8" tubes under the fronts seats shining into the back.
AEM SRI, AGP WGA, Needswings V5 DP, Tein H-Techs, DTEC-FC, Walbro 255, NGK Colder Plugs, DCR Oil Modifier, Dynotune Wet EFI, AEM A/F UEGO , AEM True Boost, Evilcreations Big FMIC, Redstar Fuel Return Line, Aeromotive FPR Greddy Type RS, ED Hardpipes, MSD Coil and Wires
350 HP or Bust
WPGSRT is offline   Reply With Quote
Old 08-14-2006, 08:48 PM   #4 (permalink)
I would love to see pictures. Do you have any ideas on where to splice into without an aftermarket HU?
Old 08-14-2006, 08:54 PM   #5 (permalink)
smoger's Avatar
Member Number: 671
Trader Rating: (25)
Raksha.. go to pep boys in the wiring section, find something called "add a circuit"
using the instructions on the package, pop it into your fusebox piggybacked onto an existing fuse..i believe i used the reverse lights since i wanted it to be switched(so i didnt have to turn it off and on manually if i didnt want to).
at this point you will have your new power wire. go from there to a switch(if you want manual control, otherwise the neons will be on all the time when the car is) to the neons.. do the same with the ground except that connects to bare metal somewhere in the car.
hope that helps.. its really pretty simple
MidAtlanticSRT
Quote: Originally Posted by mmenser
I <3 you smoger.
Quote: Originally Posted by VegasSRT-4
I don't think I've EVER agreed with smoger, the guy is an idiot.
smoger is offline   Reply With Quote
Old 08-14-2006, 09:12 PM   #6 (permalink)
wannasupra's Avatar
Member Number: 32741
i'm gonna have to check that out smoger. i put some blue pipe dream tubes in my trunk, wired em to the stock trunk light
A new lease on life...
Old 08-16-2006, 05:37 PM   #7 (permalink)
WPGSRT's Avatar
Trader Rating: (35)
Sorry I will post the pics tonite I have been busy
Old 08-18-2006, 10:51 PM   #8 (permalink)
WPGSRT's Avatar
Trader Rating: (35)
Ok I am finally putting up the pics. Tell me what you guys think. The first 2 are pics of the front and the second pic is of the back. The pic of the back isnt to good. Tell me if you think it is nice or rice.
Front:
Front:
Back:
Page generated in 0.16914 seconds with 13 queries
