Old 08-17-2006, 12:35 PM   #1 (permalink)
Member Number: 40846
Default Installed HIDs
Hey I just installed some HID's in my srt. Now the high beam indicator comes on and I can turn it off. Any ideas?
ALP5050 is offline   Reply With Quote
Old 08-17-2006, 12:48 PM   #2 (permalink)
haknslash's Avatar
Member Number: 21686
Sounds like wiring related. Who's kit and did it come with a harness to plug into the 9007?
Old 08-17-2006, 01:50 PM   #3 (permalink)
I got them from Xenon light source. Yes it did have the 9007 harness. However I suspect it has something to do with the fact that I did the ghetto foglight mod. I switched the foglight and headlight wires. But I don't think it would have any effect on the high beams seeing as I didn't have any problems before the install.
Old 08-17-2006, 04:04 PM   #4 (permalink)
haknslash's Avatar
Unpimp Z' auto.
take the ghetto mod out/switch the wires back. It will probably work correctly then. Then to get your fog lights fix, do it the right way, with the relay.
I will be a happy camper the day neon owners quit cutting corners
Old 08-17-2006, 06:17 PM   #5 (permalink)
cutting corners?? Hey at least I soldered the wires and used heat shrink. But whatever the light doesnt bother me. If something catches on fire and my turbo neon burns to the ground next to me then I'll buy a new turbo neon and do it the right way.
Old 08-17-2006, 09:02 PM   #6 (permalink)
neonelite10's Avatar
Member Number: 13966
You still cut corners by not putting a relay on it and doing it the right way, hell, if you want your fogs to come on anytime, just put a new harness together and rout a switch on your dash to it and a relay.
Your sig should not exceed 100KB
edited by peteblksrt4
neonelite10 is offline   Reply With Quote
Old 08-18-2006, 09:07 AM   #7 (permalink)
haknslash's Avatar
Now c'mon, don't take it so personal.
You even said yourself its a ghetto mod .
The fog mod is done in way that I would never do on any car. Switching wires like that can lead to issues later on down the road. Granted for our car its a small issue like the high beam indicator being on if you go to HID. But what is you get a voltage spike and send current backwards to somewhere it wasn't originally designed to go now that you've swtiched wire sources? Just a method or practice of install you won't ever catch me doing. I take precautions and the little extra time to do it right the first time so I don't have to go back later on and undo le ghetto.
It is good that you went the extra step though and soldering and used heat shrink .
Old 08-20-2006, 09:13 PM   #8 (permalink)
LOL, no I didn't take it personally... Its just a light I don't rally car that much about it. But as you said it can cause an issue later on. Sooooo if I get the motivation to switch the wires back I will.
Old 08-20-2006, 10:10 PM   #9 (permalink)
Rally car!?
LOL.
Old 08-20-2006, 10:12 PM   #10 (permalink)
Yes Car!!!!!!!!
Old 08-21-2006, 01:03 AM   #11 (permalink)
lphooper03's Avatar
Member Number: 37050
Heh....He said...Turbo neon
50 Trim + Diablosport =
Page generated in 0.22866 seconds with 13 queries
