So I took out my stage 1 today and put my stock PCM and injectors in.
See here:
Lets play: Is Ill Mac going Die in a Fire!?!?
So I get everything back in the car and go for a test drive. I turn on my headlights, and I instantly see both light up, then the driver side go out.
Long story short, here's what I checked:
1) Driver headlight out, but bright, fogs, hazards ALL WORK FINE. Tail lights and interior lights all work fine.
2) The light gave NO warning previous (dimming, flickering etc)
3) I have 2 spare bulbs: When plugged into the driver side, the bright works, but the regular light doesn't.
4) I pulled the fuse and it looked fine. <-- would anything else work anyway?
5) I check my MULTIFUNCTION SWITCH, here's what I found: It is a LITTLE toasted on the far left. The far 2 "holes" on the female end are a little melted. Under that there is a VERY small crack
It doesn't look nearly as bad as some of the other multifunction switches. In fact, I pulled the switch over 2 years ago (when I first read the "fire in dash!!" thread), and I'm pretty sure it looked similar (so long ago, I don't quite remember).
So what should I try? Should I go pick up a new multifuction switch? Is there a ground somewhere I could have knocked lose (something around the PCM since I changed that out)?
Would a bad fuse cause JUST one headlight to go out?
Ideas?
