Old 02-12-2007, 05:56 PM   #1 (permalink)
SouthShoreSRT's Avatar
Member Number: 20015
Default Idea for gauge cluster mod - need help please!
I got my Aeroforce Interceptor gauge today, and I was thinking of how I could mount it. I came up with and idea, which I hope I can describe.
I want to mount the gauge to the clear plastic that covers the stock gauges, right over the center of the tach. I held it there with my hand, and it does not block anything. You can see the needle and all the numbers around the outside. So, I think I could just get a small section of pipe from the hardware store, paint it to match, and mount that to the clear plastic like a gauge cup.
What I want to know is, first of all how hard is it to get the gauge cluster out? Is there anything I need to know to keep from damaging it? I imagine I will have to do this. Secondly, how do I separate the clear plastic from the rest of the assembly? I don't need to melt any epoxy or anything, do I? Does it just pop of or is it held on with screws?
Advice from anyone who has taken their dash apart would be welcome. Before anyone gets upset, I also want to add that I will go the junk yard and get the plastic cover - I never cut up my original parts!
The first Corvette had a six cylinder engine.
The first Porsche was still very much a Volkswagen.
Lamborghini started out as a tractor company.
The original Mustang borrowed heavily from the Falcon parts bin.
The first GTO was a LeMans option package.
The EVO is based on the Lancer.
The R32 is based on the Golf.
The SRT-4 is based on the Neon.
Judge not humble beginnings...
SouthShoreSRT is offline   Reply With Quote
Old 02-12-2007, 05:59 PM   #2 (permalink)
getnpsi's Avatar
Member Number: 14911
Trader Rating: (68)
what are you planning to do with the cable that comes off the back of it?
2004 Black. SSTv1, Stage 2 with toys, 3" exhaust with cat, Slow4DR shifter, CBD vented hood.
WTT: CBD vortex generator for a w/i kit.
getnpsi is offline   Reply With Quote
Old 02-12-2007, 06:15 PM   #3 (permalink)
Hopefully I can color it in such a way that it doesn't stick out like a sore thumb, and just run it down to a seam and out of sight.
Old 02-12-2007, 06:32 PM   #4 (permalink)
viper2pt0's Avatar
Member Number: 30503
cluster comes out easy....take out the 2 screws in the dash, one in each door jamb. pop the dash pad up....not too high unless you also remove the 2 screws in the defroster vent. once u get in there, there are 4 screws holding the cluster in. Take those out, and just pull the cluster straight out towards you. The clear plastic comes off real easy, a few torx screws and you're all set
Flame Red '05 SRT-4 ACR
Performance: Mopar BOV Conversion, Mopar STS W/ Booger bushings, F & R Strut tower bars, $20 Ebay CC, K&N DIF, GReddy Full Auto TT, DCR Bored TB & Spacer, DCR PnP Intake Manifold, JMB UPP w/ HKS Bov, NGK Iridium Plugs, QuickWhips FMIC.
Non-Performance: 2 10's in Custom Fiberglass Boxes, Homemade Grounding Kit, Glacius PC'ed Valve cover, PC'ed Intake Manifold, pwerks beam.
viper2pt0 is offline   Reply With Quote
Page generated in 0.18903 seconds with 13 queries
