Old 08-02-2006, 10:59 PM   #1 (permalink)
Member Number: 10476
Default I have been stumped as of tonight
Ok here is the scenario... I was driving and someone wanted to get over so I go to flick my high beams so they know it safe to change lanes and my headlights go out... ok no problem maybe the fuse is old and it was just it's time... the fuse that blew was number 16 in the fuse box inside the car. Ok so I replace the 25 amp fuse with another 25 amp fuse turn on headlights hit the high beams and pop there go's another fuse. Does anyone have any ideas as to why this might be happening.
2004 E-BLUE SRT-4 (The Daily Grind)
ENGINE: AGP GT3076R, return line, motor/trans mounts, CAI, 750cc inj, hard pipes w/hks bov, quickwhips fmic, MPx 3" TBE, PTP check valve
DRIVETRAIN/SUSP: ACT clutch & flywheel kit, Tokico 5 ways w/tein s-tech springs, DC sports f/r strut bars
377whp @ 23 psi on pump gas sae corrected 401 uncorrected
???whp @ ?? psi coming soon
Tuned by XxTotmacherxX
SLO-SRT4 is offline   Reply With Quote
Old 08-02-2006, 11:18 PM   #2 (permalink)
Tex
Tex's Avatar
Member Number: 3622
you have a short
-Soren Kierkegaard
Tex is online now   Reply With Quote
Old 08-03-2006, 09:17 AM   #3 (permalink)
DanielC_SRT4's Avatar
Member Number: 23707
if you have changed bulbs recently they could be causing the short
Stage 1, Eibach Pro Kit, Energy Suspension Bushings, $20 Catch Can, Prothane MM Inserts, Taylor Wires
DanielC_SRT4 is offline   Reply With Quote
Old 08-03-2006, 09:20 AM   #4 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
Quote: Originally Posted by Tex
you have a short
Old 08-03-2006, 11:47 AM   #5 (permalink)
you have a short
yeah I have narrowed it down that much. Im just trying to figure out where exactly the short is at so I can correct the problem. Was curious if anyone might of had an idea or the same problem.
Old 08-03-2006, 12:18 PM   #6 (permalink)
haknslash's Avatar
Since its only popping on high beams I'd check your wiring to make sure its not wedged on something and exposing bare wires to metal, particlarly the red high beam wire in the harness. Somewhere you have a short. If all wiring checks out fine then perhaps your bulbs are bad and have have somehow caused a direct short inside the glass. Doubtful but probable.
Is there ANYTHING you've done to the car recently?
Old 08-03-2006, 01:13 PM   #7 (permalink)
Just upgraded to big turbo. Other than that nothing electrical has been installed.
This is what im going to try when I get home. Gonna pull both headlight bulbs and try then try turning on high beams if the fuse still pops then that will lead me to believe that its a possible wire problem... if it doesn't then I will change the bulbs.
Old 08-03-2006, 04:21 PM   #8 (permalink)
haknslash's Avatar
there you go, now your thinkin'! Let us know when you find the problem and what it was.
Old 08-05-2006, 01:14 AM   #9 (permalink)
update update update.... it would seem as though the problem was with the silverstars that were in there dunno what the deal was but put some bulbs my buddy had in the car and everything works.. low beams work.. switch to high beams still works. low's on with fog's and switch to high's still works..
Page generated in 0.17647 seconds with 13 queries
