Old 02-19-2007, 01:04 PM   #1 (permalink)
Member Number: 19079
Default How to take off foglight bulb
Iam not retarded but i cant figure out how to take off the bulb!!! well maybe i am. i disconnected it and i tried turning it to take it off but it wont budge. ive taken out dozens of bulbs and i dont know wtf is wrong. help is appreciated. thanks
CANIBUS115 is offline   Reply With Quote
Old 02-19-2007, 01:17 PM   #2 (permalink)
haknslash's Avatar
Member Number: 21686
twist...pull....
Old 02-19-2007, 01:49 PM   #3 (permalink)
BlaznRedSRT's Avatar
Member Number: 43647
its very hard, i couldnt turn mine with my bare hands, i ended up taking the whole light out and twisting the bulb with pliers.
BlaznRedSRT is offline   Reply With Quote
Old 02-19-2007, 01:56 PM   #4 (permalink)
haknslash's Avatar
It's alot harder to change out fogs with the headlights still in the car. Well, for the passenger side it is because of where the horn is locatted. The driver side is easy to change from the bottom of the car.
however, to make life alot easier, just take 5 minutes and remove the headlights. Turn the bulbs counterclockwise (if you were facing the rear of the bulb) and then it will unlock.
None of this should be very hard for anyone.
Old 02-19-2007, 02:42 PM   #5 (permalink)
yea i knew all of this before trying so i wanted to see how easy it was to take of the driver side bulb and it i couldnt do it. i guess im gonna have to get some pliers. thanks for the input.
Old 02-19-2007, 05:55 PM   #6 (permalink)
Member Number: 50094
get under the car and twist, pull, replace.
dave. is offline   Reply With Quote
Old 02-19-2007, 05:58 PM   #7 (permalink)
SRTchild's Avatar
Member Number: 32169
mine was pretty hard to turn too. just took some time but then it came out.
Aem CAI, Agp WGA, Stage 1, Ndswngs V6, MPx BFIMC, Aeroforce Scangauge, AEM EUGO, MPx Dual Gauge Pods, Yellow Foglight Bulbs, Laminx, Bdjs Shorty Antenna, Eibach Pro Kit, Prothane Endlinks, ESMM, 20% Tint, PTP Coil HS, Taylor Wires, NGK 4306s, $20 Catch Can, Mopar Front Badge, SRT-4 V2 Badge, PTP Check Valve, ED Blitzz TT, TurboSmart MBC, Rota Slipstreams, Bridgestone Potenza RE-01 R's
SRTchild is offline   Reply With Quote
Page generated in 0.15284 seconds with 13 queries
