Old 03-26-2008, 02:43 PM   #1 (permalink)
ralf's Avatar
Member Number: 55887
Default how to modify headlights switching? hi/lo
I´m gonna install the halo lights on my srt, i´ve been searching for how to modify the headlight system to leave the low beam on, when you put hi beam.
I see there is a diode method, but there´s a way to modify the relay switch that change beams to leave the low beam on?
Someone have a diagram or pic?
Thanks!
Ralf
Dodge SRT-4 2004 electric blue
Bmw 330i 2002
ralf is offline   Reply With Quote
Old 04-01-2008, 12:20 PM   #2 (permalink)
morgantj13's Avatar
Member Number: 47175
first, you need to run a relay so you dont kill(the car or you)the mfs switch. Second, people have stated before that running the hi/lo on with those lights can melt(not quite destroy it, but melt a spot inside the lens) the clear plastic lens part.
You need a relay though, this is the most importnant part!!!!!!!!!!
Old 04-02-2008, 06:07 PM   #3 (permalink)
ralf's Avatar
So, you´re saying that if i turn on the low beam (with a hid bulb) and the high beam (with halogen bulb) together that will melt my headlights??
Page generated in 0.14285 seconds with 13 queries
